MaroonDuneDoom Posted December 7, 2003 Share Posted December 7, 2003 just went wheeling a bit next to my buddies house whikle i was waiting for him to gety home. i was climbing this fatty hill that my 7 year old brother said i would never get to the top of. i got to the top alright, but i went playing some more and fried the s*** out of the clutch. smoke and stink. now i can hardly get moving. this reallysucks being that it's christmas time and all. too bad Santa isn't real:boohoo: once i get it disassembled i'll take some pics and have you guys tell me whats worth keeping. maybe i wont have to buy the whole clutch kit. i don't really have $200 just laying around Link to comment Share on other sites More sharing options...
TomRhere Posted December 7, 2003 Share Posted December 7, 2003 There's a couple of things that can happen to a clutch to make it slip. Getting them over-heated is one of the major ones. When you get it pulled, look at the disc itself. If it looks all shinny, it's probally glazed over. Coarse grit sandpaper will remove that. Same with the flywheel and pressure plate. They get glazed from over heating, then they'll slip. I have resurected a few slipping clutches, just by sanding everything down a bit. May save you some cash, may not. Going to cost you some work, either way. Possibility here that you've over heated the pressure plate enough to weaken the springs/diaphram. If that is the case, you'll need a new one. Does the pedal feel way easier to push in? If so, would bet the PP is toast. All I'm saying here is, a few hours labor, may save you a few hundred dollars. Not saying it will be good as new, but it may get you by until you can afford a new one. Just got to be mindfull of the fact that the clutch is weaker now. good luck...... Link to comment Share on other sites More sharing options...
Qman Posted December 8, 2003 Share Posted December 8, 2003 Let it sit for a while. Then, go try it out again. You may very well have overheated it. I have smoked a couple clutches before. But, I have never had to replace them. Once they cool the tension comes back and works ok. Did you go through any type of water/mud hole? Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted December 8, 2003 Author Share Posted December 8, 2003 it works a bit better after cooling. it has been slipping for some time and i just pushed it over the edge. i was going to order a new clutch kit tomorrow w/a lifetime warranty. should i just replace it anyways or do the sanding. i know i'll need to replace it someday anyways. does anybody know of some type of write up for replacing the clutch? Link to comment Share on other sites More sharing options...
rgaff_77 Posted December 8, 2003 Share Posted December 8, 2003 If you have the extra money to spare, get the brand new kit with the lifetime warranty. That way if you fry it again beyond repair, it doesn't cost you anything. Otherwise do what Tom suggested. Link to comment Share on other sites More sharing options...
MaroonDuneDoom Posted December 8, 2003 Author Share Posted December 8, 2003 i came up with the cash this afternoon and i think the lifetime warranty clutch will be well worth it. this way, i can thrash the damn thing and return it again and again. i can also transfer it to my new soob when i get it. Link to comment Share on other sites More sharing options...
