mellow65 Posted September 7, 2007 Share Posted September 7, 2007 I have a camber issue on the back of my legacy and an alignment didn't fix the problem. I have some odd suspension set up going on and just would be easier to get a camber kit if they make one. Link to comment Share on other sites More sharing options...
TheYeti Posted September 7, 2007 Share Posted September 7, 2007 Call Tire Rack. They will probably have something available. Link to comment Share on other sites More sharing options...
Hocrest Posted September 7, 2007 Share Posted September 7, 2007 You can use camber bolts in place of the rear strut bolts. Summit Racing IEC-I-81260 Generally you use one bolt on each corner. They're a pain in the rump roast to use, but they are effective. Just make sure you crank them tight. For even more adjustment you can use two on each corner. Ideally if one of the control arms is bent causing the problem, it would be a good idea to replace that. Link to comment Share on other sites More sharing options...
86BRATMAN Posted September 7, 2007 Share Posted September 7, 2007 I would say that something is bent, or they didn't properly align the rear. They already have cam bolts on the rear lca's to do the alignment. Link to comment Share on other sites More sharing options...
mellow65 Posted September 7, 2007 Author Share Posted September 7, 2007 i put stock wrx shock and springs and the rear lifted up a little making the rear have a little positive camber. its about 1 degree but i would still like get it as close as possible. Link to comment Share on other sites More sharing options...
nipper Posted September 7, 2007 Share Posted September 7, 2007 Tire rack has them, and at a reasonable price. nipper Link to comment Share on other sites More sharing options...
mellow65 Posted September 7, 2007 Author Share Posted September 7, 2007 You can use camber bolts in place of the rear strut bolts. Summit Racing IEC-I-81260 Generally you use one bolt on each corner. They're a pain in the rump roast to use, but they are effective. Just make sure you crank them tight. For even more adjustment you can use two on each corner. Ideally if one of the control arms is bent causing the problem, it would be a good idea to replace that. thanks for the link i think something like this will work. what about them to use is a pain in the rump roast. Link to comment Share on other sites More sharing options...
jamal Posted September 7, 2007 Share Posted September 7, 2007 I have some ingalls or intrax or something bolts with 04 sedan struts and they get me -1.5 degrees maxed out. Anything for any Impreza or WRX or whatever will work on your car. Nothing about them is really a pain in the rump roast as long as you install them right. Put them in the top hole, place the tab on the washer toward the inside (so the little tab that sticks into the strut hole in on the outside), and rotate the bolt so the cam is facing inside. That will get you max negative camber and ensure they do not slip. Link to comment Share on other sites More sharing options...
Hocrest Posted September 7, 2007 Share Posted September 7, 2007 thanks for the link i think something like this will work. what about them to use is a pain in the rump roast. You can get them on EBay also, search "subaru camber bolt". They're not too bad, but you need to hold the bolt and the tab in the proper position while you tighten up the nut. The nut is crimped so that it doesn't come loose, but that means that you can't turn it on by hand, you need to wrench it the whole way. Also the Subie stock bolts are all 19mm heads, these are different sizes, so a two tool job becomes a 4-6 tool job. Minor things, but still a PITA. Link to comment Share on other sites More sharing options...
