Reveeen Posted September 7, 2007 Share Posted September 7, 2007 In process of rebuilding my Loyale, and doing the rear (drum) brakes, and yes I know disks are the best option, but not here, because there isn't any to be had. I'm looking at aluminum wheel cylinders, that appear to be original, what were they thinking? Link to comment Share on other sites More sharing options...
pheonix165 Posted September 7, 2007 Share Posted September 7, 2007 lets see if i'm getting this right, you have no rear brakes? Link to comment Share on other sites More sharing options...
Reveeen Posted September 7, 2007 Author Share Posted September 7, 2007 lets see if i'm getting this right, you have no rear brakes? No, I now have LOTS of rear brakes, I am questioning the *thinking* behind aluminum wheel cylinders, and their use in northern climates, in "daily driver" type cars. Link to comment Share on other sites More sharing options...
Phizinza Posted September 8, 2007 Share Posted September 8, 2007 I'm not quite following you on the "aluminum wheel cylinders" part. Can you describe to me what these are? The brake piston? The hub? Link to comment Share on other sites More sharing options...
Corolla Frenzy Posted September 8, 2007 Share Posted September 8, 2007 The drums? Datsun did that since the 60s. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 8, 2007 Share Posted September 8, 2007 Huh? You talking about the drum brake cylinder? Or the actual drum itself? "wheel cylinder" really doesn't mean much - as far as I know there's no such thing. GD Link to comment Share on other sites More sharing options...
Hodaka Rider Posted September 8, 2007 Share Posted September 8, 2007 Here's a visual aid for those of you who don't know what a wheel cylinder is: From http://autorepair.about.com/library/images/bl237lib.htm Yes, I personally think aluminum wheel cylinders are not the best choice for some climates, but they seem to work OK here in Western Canada Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 8, 2007 Share Posted September 8, 2007 I figured - I call that a drum brake cylinder. GD Link to comment Share on other sites More sharing options...
Jerry DeMoss Posted September 8, 2007 Share Posted September 8, 2007 Actually heard of a few people cracking them in really cold weather when I lived in Alaska. Around -20*f to -40*f is when I have seen them fail. Rear disks would be a good idea especially braking hard in cold weather. Link to comment Share on other sites More sharing options...
Hodaka Rider Posted September 8, 2007 Share Posted September 8, 2007 GeneralDisorder said: I figured - I call that a drum brake cylinder. GD Yah, I know you knew what they are, but you didn't understand what he said I've always been told they were wheel cylinders, ever since I was a wee boy. makes sense: you've got your master cylinder, and your wheel cylinders. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 8, 2007 Share Posted September 8, 2007 Hodaka Rider said: Yah, I know you knew what they are, but you didn't understand what he said I've always been told they were wheel cylinders, ever since I was a wee boy. makes sense: you've got your master cylinder, and your wheel cylinders. Yeah I see your point - probably a throwback from the days when hydraulic brakes first came out - drums all around so master and wheel cylinders makes sense. Now we have cylinders for all kinds of hydraulic stuff, and drums are getting rare so it's now more important to specify I suppose. Tecnically I suppose you could call the "pots" in a caliper cylinders - that's certainly what they are in hydraulic terms. Weird how the nomenclature stacks up around cars isn't it? GD Link to comment Share on other sites More sharing options...
