Adjustable Suspension On An Mv?
I have an '86 Brat GL. The front adjustment will give you about 1.5" of additional height. There are two nuts and bolts on the bottom of the upper front strut mount that raises the upper coil spring bracket. It seems to add more negative camber, but not so much that a good alignment can't offset.
