AC belt
Well... There are belts with Half inches Long / Short ... But there`s another thing to Think About: the Belt`s Wide. Let me Explain:
Since the EA82`s Belt Pulleys are shaped in a Deep "V" Design, the "Standard" Belts, known also as "A" series, Fits on the Upper Part of the Pulleys, without "Touching" their Buttom; `cos they`re Wider than the Ones I use on my EA82: the "F" Series.
I Use Equivalent Belts of the "F" Series, they gone down the Pulleys to the Buttom, and have More Grip.
So, for the "Inboard" A/C Config, I Use This:
7375Belt-SameF37.jpg?t=1189778606
Which its Number is: 11A0995, you could find it in Another Brand with That Number. is Less Wider and Half inch less Longer (Due to the Bottom of the Pulley Going), but Fits & Performs Better.
And for the Alt`s Belt, I Use This:
7440Belt-sameF43a.jpg?t=1189778610
Which Standard Number is: 11A1120.
I Suggest GoodYear`s "GatorBack" Belts.
Good Luck! :burnout:
and it's because you post important information such as this that you're one of my favorite people on this board.
Idler froze up in the Loyale...I don't know when. Got around to checking it out today though and had to remove the inner belt. Going to be replacing both belts and couldn't find the right lengths anywhere. 5 minutes of searching on here and I find this thread and then I find Jeszek's post with part #s. Thank you!
  • Like 1
and it's because you post important information such as this that you're one of my favorite people on this board....
... 5 minutes of searching on here and I find this thread and then I find Jeszek's post with part #s. Thank you!
You're Welcome, my dear Friend.  :)
Remember, these numbers are intended for the EA82 with "inboard" A/C,
Factory "Hitachi" Compressor, between the Alternator and the Power Steering Pump
Not for the "outboard" A/C Compressor, which is "Panasonic", a dealer installed option.
Kind Regards.
