75subie Posted September 10, 2007 Share Posted September 10, 2007 i did i quick search, but i just want to make sure this info is correct will a 1995 ej22 engine out of a legacy automatic awd, bolt and plug into a 98 forester automatic? any drilling or swapping of mounts neccessary? thanks for any help Link to comment Share on other sites More sharing options...
Manarius Posted September 10, 2007 Share Posted September 10, 2007 i did i quick search, but i just want to make sure this info is correct will a 1995 ej22 engine out of a legacy automatic awd, bolt and plug into a 98 forester automatic? any drilling or swapping of mounts neccessary? thanks for any help The engine will bolt in. Will it wire up correctly? Probably not. The Forester had an EJ25, not an EJ22. Link to comment Share on other sites More sharing options...
86BRATMAN Posted September 10, 2007 Share Posted September 10, 2007 Pretty sure you're correct Jon, AFAIK the 8 bolt did start until 99 for the ej25 motors. Link to comment Share on other sites More sharing options...
86BRATMAN Posted September 10, 2007 Share Posted September 10, 2007 The engine will bolt in. Will it wire up correctly? Probably not. The Forester had an EJ25, not an EJ22. Yes it will wire right. Many people have done it in outbacks. Link to comment Share on other sites More sharing options...
75subie Posted September 10, 2007 Author Share Posted September 10, 2007 thanks guys, wanted to be certain before i pull a motor at the jy. Link to comment Share on other sites More sharing options...
Manarius Posted September 10, 2007 Share Posted September 10, 2007 Yes it will wire right. Many people have done it in outbacks.It will wire right, but I think he's going to have issues with the fact that the 95 EJ22 isn't OBDII? Well, I guess it depends on when it was built. It'll work, it'll just take some effort... Link to comment Share on other sites More sharing options...
86BRATMAN Posted September 10, 2007 Share Posted September 10, 2007 It will wire right, but I think he's going to have issues with the fact that the 95 EJ22 isn't OBDII? Well, I guess it depends on when it was built. It'll work, it'll just take some effort... Using stock ej25 sensors and wiring, it is as easy as installing another ej25 in its place. In all actuality, probably only slightly harder than my instalation of a my91 ej22 into a my95 obd2 wagon... Link to comment Share on other sites More sharing options...
mellow65 Posted September 10, 2007 Share Posted September 10, 2007 It will wire right, but I think he's going to have issues with the fact that the 95 EJ22 isn't OBDII? Well, I guess it depends on when it was built. It'll work, it'll just take some effort... actually the ej22 from a 95 legacy was obdII, they started when they changed the body style. Also an odd one that I never new, was the impreza, in 95, the 1.8 were obdI and the 2.2 was obdII. I know this because I have owned both of them. Link to comment Share on other sites More sharing options...
Manarius Posted September 10, 2007 Share Posted September 10, 2007 actually the ej22 from a 95 legacy was obdII, they started when they changed the body style. Also an odd one that I never new, was the impreza, in 95, the 1.8 were obdI and the 2.2 was obdII. I know this because I have owned both of them. On top of that, the SVX (EG33) was OBDI in 1995 too. I have one Link to comment Share on other sites More sharing options...
backwoodsboy Posted September 10, 2007 Share Posted September 10, 2007 Jon, This is too odd! (Im doing the same thing except my Forester is a '99 A/T) As far as Ive heard, you should be fine as long as its an OBDII. (I hope for both our sakes) Link to comment Share on other sites More sharing options...
mellow65 Posted September 10, 2007 Share Posted September 10, 2007 and normally people find the 95 ej22s because they were still duel ports for the exhaust so everything would bolt up to the ej25 headers. i think somewhere in 96-97 they went to a single port at that point you would have to use single port headers. Link to comment Share on other sites More sharing options...
DerFahrer Posted September 10, 2007 Share Posted September 10, 2007 I don't think it's going to wire up perfectly if the outgoing engine is a DOHC and the ingoing engine is a SOHC. Also, if your state has emissions/inspections, understand that in some cases, it's illegal to put an older engine into a newer car. Link to comment Share on other sites More sharing options...
subaru360 Posted September 10, 2007 Share Posted September 10, 2007 I've done this swap 4 times. If you get an EJ22 with egr everything plugs in. Even without EGR it all plugs in you just get a CEL. If you get one without EGR and you grab the ECU as well it won't have a CEL and will pass inpection in states where all they do is plug in to the car The new ECU won't be looking for an EGR, all the OBD2 monitors will set and the EGR monitor will come up N/A. Obviously it will fail a visual, but if you got an underhood sticker without egr you might be ok there. You can use a 96-98 EJ22 if you get the single port y pipe when you get the engine. The ej25 p/s lines don't line up with the ej22 intake. I just let it go, never had a problem, but if you're picky you can either make a bracket or swap to ej22 lines. Be sure to swap flexplates if it's an auto the EJ22 one is smaller. The only problem I ever had with an EJ25 to EJ22 swap was once I swapped ECU's and the car I got the donor ECU from had some odd emissions maybe california? It had a fuel temp sensor. So I had to swap fuel tank sending units and run a wire to the ECU. Link to comment Share on other sites More sharing options...
3Pin Posted September 10, 2007 Share Posted September 10, 2007 The swap works great. I did it on my 98 Forester. Donor egine was a 95 automatic. The flywheel needs to be transferred from the 2.5 to the 2.2 also. No egr problems if you had an automatic 2.5 in there and the new motor is automatic also. Look at all the other recommeded things to replace while the motor is out, because now is the time when she is out of there. I think if you did a search on HG repair, there is a list out there, like Timing belt, seperator plate, water pump, oil pump seals, plugs, water pump etc.... Good luck! Link to comment Share on other sites More sharing options...
