subaruguru Posted September 11, 2007 Share Posted September 11, 2007 ok so i put this engine together and it wont start. it gets spark and fule and air but still it just kinda chuggs. ughghghg what are some small things that i coulda overlooked:-\ Rob Link to comment Share on other sites More sharing options...
mikeshoup Posted September 12, 2007 Share Posted September 12, 2007 Timing belts correct? Distributor timing correct? All the hoses are plugged correctly? You didn't swap the fuel supply with the fuel return? (I did this once...) So many things you unplugged, and so many things you could have forgotten to plug back in. Link to comment Share on other sites More sharing options...
TheBush Posted September 12, 2007 Share Posted September 12, 2007 Its pretty much gotta be the timing right? The timing or that the compression is so bad it won't start? Link to comment Share on other sites More sharing options...
subaruguru Posted September 12, 2007 Author Share Posted September 12, 2007 i checked everything i know i did the timeing rite im going to check everything again but idk. Link to comment Share on other sites More sharing options...
mikeshoup Posted September 12, 2007 Share Posted September 12, 2007 i checked everything i know i did the timeing rite im going to check everything again but idk. If it ran before, then you didn't do something right. Double check everything. If it comes down to it, do a compression test and make sure that engine you put in is capable of running. Link to comment Share on other sites More sharing options...
subaruguru Posted September 12, 2007 Author Share Posted September 12, 2007 well all i have to go on is carfreak said it was a good engine i changed the headgaskit and put it in and it wont start i torqued the heads and all. Link to comment Share on other sites More sharing options...
j2coe Posted September 12, 2007 Share Posted September 12, 2007 disty in 180 degrees off? I suppose it wouldnt even chug if it was, just crank but not turn over. I didn't tighten my air intake once and it would just start but died as soon as I gave it gas, it was hard to see, stupid mistake and took a while to find. double check your connections like mikeshoup suggested. Link to comment Share on other sites More sharing options...
subaruguru Posted September 12, 2007 Author Share Posted September 12, 2007 yeah im doin that and im also gong to check the timing again Link to comment Share on other sites More sharing options...
carfreak85 Posted September 12, 2007 Share Posted September 12, 2007 My guess is that the cams are out of phase with the pistons. Go thought the procedure for installing timing belts to make sure that they are lined up correctly. Link to comment Share on other sites More sharing options...
Jub Nub Posted September 12, 2007 Share Posted September 12, 2007 +1 on the cam timing.. when i put mine together we had one side 180 degrees off and it did the same thing. really pissed me off too... Link to comment Share on other sites More sharing options...
TheBush Posted September 13, 2007 Share Posted September 13, 2007 I really hope SubaruGuru can figure it out...I need that car running.... :-\ Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted September 13, 2007 Share Posted September 13, 2007 Are you sure you're getting compression? I have a compression tester you can borrow if you'd like.. Link to comment Share on other sites More sharing options...
TheBush Posted September 14, 2007 Share Posted September 14, 2007 Hopefully something because like I said, I really need SubaruGuru to figure it out... Link to comment Share on other sites More sharing options...
subaruguru Posted September 14, 2007 Author Share Posted September 14, 2007 it has compression but i guess bring it over and we can check it. Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted September 14, 2007 Share Posted September 14, 2007 K. If not tomorrow night, then sometime saturday afternoon. Link to comment Share on other sites More sharing options...
baccaruda Posted September 14, 2007 Share Posted September 14, 2007 check the timing belts.. you should be able to correct them, if they're the problem, without having to pop off the crank pulley.. see if they're off and if so, then loosen the tensioner(s) through the holes in the center cover and move the wrong belt(s) around until in the right position. the timing belt procedure is somewhere in here: http://ultimatesubaru.org/forum/forumdisplay.php?f=44 about 25 posts down is Miles Fox's EA82 timing belt guide .. it's the 4th one down with 5 stars. good luck. Link to comment Share on other sites More sharing options...
