swilde20 Posted September 12, 2007 Share Posted September 12, 2007 i'm looking at buying a 97 legacy wagon that has no power windows and a tach less dash and was wondering if the wiring was there from the factory if i was to put on some other doors i have with all the power options and a different gauge set with a tach? i know some car builders do that to save time and money. thanks steve Link to comment Share on other sites More sharing options...
porcupine73 Posted September 12, 2007 Share Posted September 12, 2007 Sounds like it is a brighton. Not sure about the power locks stuff, but the tach signal is definitely there. On my '96 leg brighton I tapped the wire on one of the connectors to the instruent panel that would have gone to the tach and used that to run an aftermarket tach and it worked. Link to comment Share on other sites More sharing options...
subaru key collector Posted September 12, 2007 Share Posted September 12, 2007 porcipune73, your leggys have no power locks? Link to comment Share on other sites More sharing options...
86BRATMAN Posted September 12, 2007 Share Posted September 12, 2007 I had a 95 brighton, swapped in a cluster from a 96 L and everything worked perfectly. I however did not look into locks, windows, or mirrors. If the wiring is there, you'll still need relays, swithes and all that fun stuff. Link to comment Share on other sites More sharing options...
porcupine73 Posted September 12, 2007 Share Posted September 12, 2007 subaru key collector said: porcipune73, your leggys have no power locks?Nice keys! My '96 is a brighton, it does not have power locks, power windows, ABS, and it has rear drums. My '94 has all of those. Link to comment Share on other sites More sharing options...
