SakoTGrimes Posted September 15, 2007 Share Posted September 15, 2007 I am not a mechanic. I have no idea what to do. What it needs: something done to the carburettor, possibly the engine - I'm getting nauseating (and embarrasing) amounts of black and whitish blue smoke out the exhaust and something needs to be done with the brakes. They are very very weak and make knocking noises. If you know what you're doing and want an extra $2-300 lemme know. This is the closest thing I have to a legally drivable car and I need it fixed. Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted September 15, 2007 Share Posted September 15, 2007 If its Black smoke, that means its burning too much fuel. If its white smoke, that means its burning coolant. If its blue smoke, that means you are burning oil. If it is black, white & blue smoke, that means you have a serious problem somewhere, most likely internally. Brakes are easy -Brian Quote Link to comment Share on other sites More sharing options...
nipper Posted September 15, 2007 Share Posted September 15, 2007 Isnt white a new pope? A subaru is a great car to learn on as far as the brakes. Get yourself a good manual and sit down and read it. Hayens is best.Start with a tuneup (plugs cap wires rotor air fule filter). If you can find someone to do it with, let them teach you, while you do it yourself. nipper Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 15, 2007 Share Posted September 15, 2007 If I were closer I would help you out - you should lookup some of the Medford crew - find Adam or Tony. I think Adam may still be out of country with the national guard but Tony (Soobme) might be around. I hear he's into Nissan's or something now but he's a real, real good guy and could at least point you in the right direction if not actually assist you with the job. Might even end up with a roll bar or brush guard or something as he's a good fabricator. GD Quote Link to comment Share on other sites More sharing options...
Cougar Posted September 15, 2007 Share Posted September 15, 2007 Try replacing the PCV valve and see if that helps clear up the smoke situation. It will be near the carburator. If you need help finding it, I would think a parts store would give you a hand. Quote Link to comment Share on other sites More sharing options...
tysn Posted September 16, 2007 Share Posted September 16, 2007 there is a subaru specialist i think to the west side of front street before you get to or even to the nissan dealership. and there also use to be a subaru guy on south pacific highway by the purple parrot. Quote Link to comment Share on other sites More sharing options...
SakoTGrimes Posted September 16, 2007 Author Share Posted September 16, 2007 John got forced out of his shop and no longer works on Rus and the last time I went to DHM Dave was MIA and there were a couple of 4th grade flunkies running the shop, otherwise I'd take it to one of them - Medford is without a professional Subaru mechanic for the time Quote Link to comment Share on other sites More sharing options...
Bucky92 Posted September 16, 2007 Share Posted September 16, 2007 I wish I was closer...I would love to help also..I know some about the brakes and I love helping people..either teaching them what ( little) I know and in return..learning what they know. Its also fun. Also as for the smoking issue..I was thinking the same as Cougar..PCV..Always start simple..also...when you can search here for step by step repairs..or get a manual...I thought that doing a rear disk swap "sounded" hard...but I tried it anyway and it was very easy..You can fix your Brat..I have faith in you...If I can do this stuff so can you:grin: Quote Link to comment Share on other sites More sharing options...
xoomer Posted September 17, 2007 Share Posted September 17, 2007 Edit (must remember to check locations before posting an I will help) Quote Link to comment Share on other sites More sharing options...
calebz Posted September 17, 2007 Share Posted September 17, 2007 Edit (must remember to check locations before posting an I will help) Sea-Tac to medford is a hell of a drive. ( I drove Puyallup to Medford a few years ago - long, but nice drive) Quote Link to comment Share on other sites More sharing options...
chef_tim Posted September 17, 2007 Share Posted September 17, 2007 This sounds like a job for Miles Fox and the Traveling Subaru Gypsies Quote Link to comment Share on other sites More sharing options...
SakoTGrimes Posted September 30, 2007 Author Share Posted September 30, 2007 bump - I'm willing to compensate for traveling expenses.... moneeeeee! Quote Link to comment Share on other sites More sharing options...
nipper Posted September 30, 2007 Share Posted September 30, 2007 bump - I'm willing to compensate for traveling expenses.... moneeeeee! hrmmm NY to oregon... Someone up there has to want help... people, stop playing in mud for a few hours and give him a hand please nipper Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted October 1, 2007 Share Posted October 1, 2007 Will the car make it over the pass to K. Falls? We could probably work something out. The brakes are easy enough to do; after you do them the first time that is (The first time I did brakes it took a few days ) Not sure about the other smoking issue though. Aside from a compression test... Is it an automatic or manual? -Dave Quote Link to comment Share on other sites More sharing options...
SakoTGrimes Posted October 1, 2007 Author Share Posted October 1, 2007 4 speed. I'm pretty sure I've got good or at least decent compression, she still goes well in the high RPMs like she should, there's just a lot of smoking at idle, plus a flamy backfire on shutdown. I'm sure she would make it to Klamath OK. Quote Link to comment Share on other sites More sharing options...
hooziewhatsit Posted October 1, 2007 Share Posted October 1, 2007 That does kinda sound like it's running rich. Does it smell like it's running rich? How's the fuel mileage on it? I'll admit I'm just past a noob when it comes to carbs. If we can get some ideas to check on here, I'd feel a lot more comfortable messing with it. -Dave Quote Link to comment Share on other sites More sharing options...
SakoTGrimes Posted October 1, 2007 Author Share Posted October 1, 2007 Definately running rich. Lots of headache inducing fumes and 12.1 mpg Quote Link to comment Share on other sites More sharing options...
westernova Posted October 3, 2007 Share Posted October 3, 2007 Still looking for help I am in Talent? Quote Link to comment Share on other sites More sharing options...
