disty swappin action
im runing another wierd combination. spfi long block, with carb manifold, and weber.
i have two distributors. one is from a carb ea82 4x, with one vac point and two wires. the other one is off an 85 mpfi, with two vac points.
i know both will work, but would the one with two vac points be a progressive advance. like better?
if i use the one with the two vac points, could i just t one vac line to both of them, or does one go before throttle plate, and one after?
somebody shed some light please
