bgambino Posted September 16, 2007 Share Posted September 16, 2007 I am finally finishing up a HG job I started loong ago I was about to put the valve covers on....I have the 6 bolts and new grommet washers...but I see two more bolt holes in the VC in the center that tighten around the spark plug rubber gaskets. Can someone remind me what the hell these bolts look like??? I don't see anything in my bags of parts that go in the holes....or some kind of gasket washer either....this is the problem waiting a year to finish a job thanks 96 2.5 DOHC Link to comment Share on other sites More sharing options...
mdjdc Posted September 17, 2007 Share Posted September 17, 2007 There is not a bolt there. I have done two recently and those were empty when I pulled the cover. Probably a design to hold down the plug wires. Don't worry about them Link to comment Share on other sites More sharing options...
xrturbo Posted September 18, 2007 Share Posted September 18, 2007 For some reason those are only in the 96 VC's, the ones that say four cam on them. They are also the only ones that take that style spark plug wire. Link to comment Share on other sites More sharing options...
bgambino Posted September 20, 2007 Author Share Posted September 20, 2007 There is not a bolt there. I have done two recently and those were empty when I pulled the cover. Probably a design to hold down the plug wires. Don't worry about them that sure seems strange as there is definitely a hole with threads in the head. The spark plug gasket (on the v cover) has a hole in it that the bolt would go thru(there are 2 in each cover) These sure seem like they should have bolts as it would draw the valve cover in tight and compress the gaskets well Anyone have a 96 ish DOHC and can look I could post a pic if needed Link to comment Share on other sites More sharing options...
xrturbo Posted September 20, 2007 Share Posted September 20, 2007 Take our word it doesn't use a bolt there. Look at your spark plug boot (assuming they are sube wires) they have a nipple that actually drops into that hole. Link to comment Share on other sites More sharing options...
bgambino Posted September 21, 2007 Author Share Posted September 21, 2007 Take our word it doesn't use a bolt there. Look at your spark plug boot (assuming they are sube wires) they have a nipple that actually drops into that hole. sorry guys I do have subie wires and there is no nipple--there's a big flat flap on the end of wire that covers this hole along with the spark plug opening There is clearly a large threaded hole in the head to receive a bolt--2 on each side can someone advise how to post photos? this mystery is bugging me....thanks Link to comment Share on other sites More sharing options...
Gnuman Posted September 21, 2007 Share Posted September 21, 2007 The holes on the heads are on all DOHC 2.5's. When I saw them, I assumed they were for a COP (Coil On Plug) option. Never saw the wires that cover them though. there is no bolt that goes into them at all on the standard configuration. I have done dozens of these HG's. skip those bolt holes. It is bad enough that the wires sit almost right up against the frame rails as is. . . Adding a bolt there will only make your life harder as you maintain the vehicle down the road. Link to comment Share on other sites More sharing options...
xrturbo Posted September 21, 2007 Share Posted September 21, 2007 I am doing another set of HG's this time on a 99 and that also has the holes, along with the nipple on the plug wire boot that drops into the hole. Link to comment Share on other sites More sharing options...
mdjdc Posted September 21, 2007 Share Posted September 21, 2007 okay, several posters have said it.....there is no bolt for thaat hole. Now just go with the flow and finnish your engine. Link to comment Share on other sites More sharing options...
