Sonicfrog Posted September 16, 2007 Share Posted September 16, 2007 OK so anyone who has an EA82 has probably dealt with a loose oil cap, shown here in a video compliments of Corolla Frenzy. Question, will an oil fill tube from an EJ22 bolt right on to an EA82? I'm going to the J-Yard today and will investigate while there. Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted September 16, 2007 Share Posted September 16, 2007 Just buy a new oil cap. You can get 'em at most parts stores. Quote Link to comment Share on other sites More sharing options...
Bucky92 Posted September 16, 2007 Share Posted September 16, 2007 Just buy a new oil cap. You can get 'em at most parts stores. I probably have 2 or 3 laying around here..I snag them at the JYs cause I sometimes dont have it tightened down and Buck will blow his off. Quote Link to comment Share on other sites More sharing options...
Sonicfrog Posted September 16, 2007 Author Share Posted September 16, 2007 Just buy a new oil cap. You can get 'em at most parts stores. Oh, your ruining all the fun:banana::banana:!!! Quote Link to comment Share on other sites More sharing options...
daeron Posted September 17, 2007 Share Posted September 17, 2007 alot of the time you can simply bend the tabs on the underside of the oil cap down. The key is bending them down enough to tighten the fit without making it too tight to put on. If you need a new seal, those are more commonly available than you might think.. easy to find one in the junkyard at least. Quote Link to comment Share on other sites More sharing options...
heartless Posted September 17, 2007 Share Posted September 17, 2007 have had success "fixing" a loose oil cap by prying the seal out and flipping it over - put cap fully back on then back it up until it "tightens" - worked for me anyway... Quote Link to comment Share on other sites More sharing options...
j2coe Posted September 17, 2007 Share Posted September 17, 2007 they have oil caps? I thought they cam from the factory with rags stuck in there so you can wipe the oil dipstick. Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted September 18, 2007 Share Posted September 18, 2007 i made a new gasket out of cork Quote Link to comment Share on other sites More sharing options...
Reveeen Posted September 18, 2007 Share Posted September 18, 2007 they have oil caps? I thought they cam from the factory with rags stuck in there so you can wipe the oil dipstick. Mine came with an old work sock! Actually, the cap was there all along, it got dropped down on the, well, I don't have a clue what they are called, the tin shields found on each side beside the rad, it disappeared in the collected crud, only to be rescued later (by myself), and re-installed. Quote Link to comment Share on other sites More sharing options...
Virrdog Posted September 24, 2007 Share Posted September 24, 2007 OK so anyone who has an EA82 has probably dealt with a loose oil cap, shown here in a video compliments of Corolla Frenzy. Question, will an oil fill tube from an EJ22 bolt right on to an EA82? I'm going to the J-Yard today and will investigate while there. Definitely find out. That would be great to have the larger opening. Of course, I have both in my driveway. Maybe I should just go look. Quote Link to comment Share on other sites More sharing options...
Sonicfrog Posted September 24, 2007 Author Share Posted September 24, 2007 OK. I forgot to check on this the last week-end at the J-Yard. I'm going back this week-end to get a couple of trannies, one for an 84 Tercel, and maybe one for Murph to replace the 5 speed leaky tranny. That will be a bummer as that is the famed Full Time 4 WD with the locking diff., and I doubt I will be able to find one at the yard, but I do have my fingers crossed. Quote Link to comment Share on other sites More sharing options...
r_kirky Posted September 26, 2007 Share Posted September 26, 2007 Just buy a new oil cap. You can get 'em at most parts stores. +1 I bought one from schmucks for about Five dollars Quote Link to comment Share on other sites More sharing options...
