Subaru_dude Posted September 16, 2007 Share Posted September 16, 2007 I've already taken everything apart and need to remove the ball joint but it's being quite contrary. I can't put the nut back on cuz it's too flugged up. I've removed that little bolt that clamps it's housing (or whatever that thing is) shut. I've pried and pried, but it's not moving. I think I was supposed to leave the bearing housing in the car to do it... but it's too late now. I've been trying to grab it with channel locks to pull it out but that doesn't work either. What should I do? I need the car for tomorrow so it's kinda urgent. Thanks guys. Link to comment Share on other sites More sharing options...
john in KY Posted September 16, 2007 Share Posted September 16, 2007 You need to "spread" whatever that thing is called the ball joint lives in. Use a large screwdriver or cold chisel. Sink it in with a few good whacks with a hammer. Link to comment Share on other sites More sharing options...
Reveeen Posted September 16, 2007 Share Posted September 16, 2007 But carefully, it is cast, and you might not like the next noise you hear. Link to comment Share on other sites More sharing options...
Subaru_dude Posted September 17, 2007 Author Share Posted September 17, 2007 Yeah, that's why I didn't try that to begin with... I didn't know how much pounding it could take. Well, new ball joints in order for me. Link to comment Share on other sites More sharing options...
idosubaru Posted September 17, 2007 Share Posted September 17, 2007 if all is normal - healthy slamming to pry that opening open will work just fine. hammer and a chisel. if it's corroded and seized in there at all - you need heat. heat the outer perimter, not the actual ball joint itself. a good torch is best, but a propane may work if it's not too bad and they're cheap and more readily available. Link to comment Share on other sites More sharing options...
Subaru_dude Posted September 17, 2007 Author Share Posted September 17, 2007 Thank goodness it wasn't siezed up... probably because that corner of the car was caked up in grease because eveytime that axle started clicking I would just crawl under there with a handful of grease and slap it in the axle cup and call it good. Link to comment Share on other sites More sharing options...
