Soutthpaw Posted September 17, 2007 Share Posted September 17, 2007 I cannot seem the get the specified 20 degree BTDC timing on my 86 DL10 Turbo wagon. lining up the distrubutor I can get about 12 Degrees max and if i move the distributor one tooth I am at min of about 25 degrees. I have just put a new distrubutor and new timing belts on this engine too. If anyone has had the same problem or any ideas that would be great thanks DJ Link to comment Share on other sites More sharing options...
daeron Posted September 17, 2007 Share Posted September 17, 2007 first off, it should be a GL-10. Secondly, did you have the green connectors plugged in? that is necessary for setting the timing; think of it as "disabling the vacuum advance" on a carb'ed car. Link to comment Share on other sites More sharing options...
j2coe Posted September 17, 2007 Share Posted September 17, 2007 what is the idle speed once you connect the green test plugs for setting the timing? should be 800 for setting timing. adjustment idle speed adjust is in a recessed hole on the back of the air intake at the top of the manifold. Link to comment Share on other sites More sharing options...
calebz Posted September 17, 2007 Share Posted September 17, 2007 IIRC, 85-86 Turbos do not use the 20BTDC setting. Its supposed to be something like 8* All of my manuals are for 87+, so I don't have any way to confirm the exact number, but I am 99.99999% sure that the 85-86 (vane MAF cars) use a different timing setting than the later ones. Link to comment Share on other sites More sharing options...
j2coe Posted September 17, 2007 Share Posted September 17, 2007 just flipped the haynes open, it says all 85 and 86 turbo 25 degrees BTDC. that's new to me. Link to comment Share on other sites More sharing options...
Soutthpaw Posted September 17, 2007 Author Share Posted September 17, 2007 yeah its GL10 and turbo 85 86 are 25* which is stupid cuz there is no 25* non turbo is 8* Link to comment Share on other sites More sharing options...
j2coe Posted September 17, 2007 Share Posted September 17, 2007 each mark is 2 degrees, so the 10 is 20 degrees, etc, you probably know that but some people don't, and it messes them up. Link to comment Share on other sites More sharing options...
Sonicfrog Posted September 17, 2007 Share Posted September 17, 2007 each mark is 2 degrees, so the 10 is 20 degrees, etc, you probably know that but some people don't, and it messes them up. Hu-Wha..............?????? Link to comment Share on other sites More sharing options...
j2coe Posted September 17, 2007 Share Posted September 17, 2007 well the ones on the fly wheel, turbos are supposed to have a timing mark on the main pully and the scale on a plastic thing next to it but none of mine do. so I always have to use the marks on the fly wheel. Link to comment Share on other sites More sharing options...
j2coe Posted September 17, 2007 Share Posted September 17, 2007 I guess I wrote that wrong the numbers are right, the marks are each 2 degrees, so 10, and 20, marks are right, but each notch is 2 degrees not 1, sorry for the confusion. Link to comment Share on other sites More sharing options...
Soutthpaw Posted September 17, 2007 Author Share Posted September 17, 2007 Ok got it figured out. its all set now. Thanks. Also found that green connector which is under the dash on this model Link to comment Share on other sites More sharing options...
calebz Posted September 17, 2007 Share Posted September 17, 2007 just flipped the haynes open, it says all 85 and 86 turbo 25 degrees BTDC. that's new to me. Ah - got it. Thanks for the correction. I knew the 85-86 was different. Just couldn;t remember what it was. Link to comment Share on other sites More sharing options...
Sonicfrog Posted September 17, 2007 Share Posted September 17, 2007 I guess I wrote that wrong the numbers are right, the marks are each 2 degrees, so 10, and 20, marks are right, but each notch is 2 degrees not 1, sorry for the confusion. Egads, you scared me. I was about to run out and re-time Murph.... Oh hell, maybe I'll go out and do it anyway!!!:banana: Link to comment Share on other sites More sharing options...
j2coe Posted September 17, 2007 Share Posted September 17, 2007 yeah, sorry, my thoughts and my typing don't always connect quite right Link to comment Share on other sites More sharing options...
Soutthpaw Posted September 17, 2007 Author Share Posted September 17, 2007 just flipped the haynes open, it says all 85 and 86 turbo 25 degrees BTDC. that's new to me. According to my Alldata which I generally trust over a DIY manual, the timing for 85 86 are as follows 1781cc turbo 25* 1781CC MPFI 6* 86' 1781CC TBI 20 +/-2* 1595 & 1781cc 2v 8+/- 2* Link to comment Share on other sites More sharing options...
