Rear wheel bearing EA82 2WD
Mac
Haven't pulled the wheel yet but know I need a rear wheel bearing on my '85 DL Sdn, 2WD.
Was checking parts. Some parts houses say on this model there is an inner and outer bearing as well as a seal. Others say just the inner and out bearing.
Question: Does it have a seal?
lemme check my hanyes manual.
85 2wd drive is says (this is from inside to outside of the whole assembly)
1. O ring
2 spacer
3 oil seal
4 inner bearing
5 Outer bearing
6 Lock plate
7 lock washer
8 axle nut
9 o ring
10 grease cap
The only seal that there is, goes on the inside part of the stub shaft where hte cv axle connects (#3)
