Rastrahouse Posted September 19, 2007 Share Posted September 19, 2007 How do I find out what the gear and final drive ratios are for my 1999 legacy GT 2.5L 30A with a 5 speed manual are? I am trying to figure out the shift points for the best acceleration. Link to comment Share on other sites More sharing options...
idosubaru Posted September 19, 2007 Share Posted September 19, 2007 check out the search button. search for "gear ratio" and narrow the search down to new generation forum and a title search first. links to subaru MT gear ratios are around. Link to comment Share on other sites More sharing options...
johnceggleston Posted September 19, 2007 Share Posted September 19, 2007 search trranychart. Link to comment Share on other sites More sharing options...
xrturbo Posted September 19, 2007 Share Posted September 19, 2007 I think they are 4.11s. That trans is the same as the 99-01 RS trans. Link to comment Share on other sites More sharing options...
idosubaru Posted September 19, 2007 Share Posted September 19, 2007 I think they are 4.11s. That trans is the same as the 99-01 RS trans. while i thought they were 4.44, i think that's only part of what he's looking for, that's the final drive ratio. many auto's are 4.11 and i thought the GT's were 4.44? i think he's looking for complete gear ratio charts. Link to comment Share on other sites More sharing options...
johnceggleston Posted September 19, 2007 Share Posted September 19, 2007 he has a 5 speed 2.5L, it's 4.11. 95 - 99 legacy final drive ratios auto trans 2.2L = 4.11 2.5L = 4.44 5 speed 2.2L = 3.9 2.5L = 4.11 i have always assumed that the reason they lowered gearing in the final drive in the when they used the 2.5L engine was because generally the cars were heavier and needed it. but now i wonder if the final drive ratio isn't more associated with the wheel / tire circumference. in 96 when they introduced the 2.5L engine with the 4.44 final drive, every car they put in had 15" wheels (i think) outback, GT, and LSi. why would a more powerful engine need a more powerful final drive ratio? i can see where a bigger wheel would need one. just a thought. Link to comment Share on other sites More sharing options...
xrturbo Posted September 20, 2007 Share Posted September 20, 2007 4.44 is an auto gear ratio in the US Link to comment Share on other sites More sharing options...
xrturbo Posted September 20, 2007 Share Posted September 20, 2007 The GT's were 16 inch wheels. You are probably right with the reasoning, more grunt for the larger outback tires, and a little more snot for the GT. Link to comment Share on other sites More sharing options...
Rastrahouse Posted September 20, 2007 Author Share Posted September 20, 2007 search trranychart. What is trranychart? Link to comment Share on other sites More sharing options...
johnceggleston Posted September 20, 2007 Share Posted September 20, 2007 What is trranychart? click on the search tab at the top of this page and type in 'trannychart'. you'll find a link which will deliver a list of all manual transmissions, foreign and domestic with the gear ratios, final drive ratios and type of AWD center differential. Link to comment Share on other sites More sharing options...
Rastrahouse Posted September 20, 2007 Author Share Posted September 20, 2007 click on the search tab at the top of this page and type in 'trannychart'. you'll find a link which will deliver a list of all manual transmissions, foreign and domestic with the gear ratios, final drive ratios and type of AWD center differential. Found it, Thanks! http://www.northursalia.com/techdocs/trannychart/trannychart.pdf TY754VCAAB 1st 3.545 2nd 2.111 3rd 1.448 4th 1.088 5th 0.78 Final drive 4.111 Link to comment Share on other sites More sharing options...
