Caboobaroo Posted March 8, 2009 Share Posted March 8, 2009 if you can get a pic of the threads, you might be able to retap them and fix them. Only way you're gonna fix it... Link to comment Share on other sites More sharing options...
Kostamojen Posted March 8, 2009 Author Share Posted March 8, 2009 I'm contemplating cutting off the bad first couple of threads (since they are "squished" which made them wide and too narrow to thread through) but it would put it close to the hole that the pin goes through... I already used that procedure with a couple of other spots on the suspension I fubared where clearance wasn't an issue, but with these there is less wiggle room. Link to comment Share on other sites More sharing options...
XT6 Magic Posted March 8, 2009 Share Posted March 8, 2009 You can always grind the diameter of the damaged section down closer to where it was and then either use a thread file of the correct pitch and do it by hand or use a re-threading die. You should be able to fix them without having to cut any material off. Working with some other techs over the years has improved my skills in damaged thread repair:grin: BTW I have been watching this thread from the beginning and it is looking great. Keep up the details and pics! Link to comment Share on other sites More sharing options...
Kostamojen Posted March 8, 2009 Author Share Posted March 8, 2009 Hmm, thread file, I'll have to check that out. Someone mentioned a thread die elsewhere and that seems like an expensive contraption. Link to comment Share on other sites More sharing options...
XT6 Magic Posted March 8, 2009 Share Posted March 8, 2009 (edited) These are the ones I have and they work great. http://buy1.snapon.com/catalog/item.asp?item_ID=9693&group_ID=1149 Edited March 9, 2009 by XT6 Magic Link to comment Share on other sites More sharing options...
Kostamojen Posted March 8, 2009 Author Share Posted March 8, 2009 These are the ones I have and they work great. http://buy1.snapon.com/catalog/item.asp?item_ID=9693&group_ID=1149 Snap-on Update The Snap-on.com website is not available due to a system upgrade that is now underway. This is part of our continuing efforts to improve our website for you, our valued customers. Please try again later. LOL!!! Link to comment Share on other sites More sharing options...
naru Posted March 8, 2009 Share Posted March 8, 2009 Hmm, thread file, I'll have to check that out. Someone mentioned a thread die elsewhere and that seems like an expensive contraption. This one isn`t too pricey.Looks like it has your size.Should be able to buy just one thru a local jobber too. http://cgi.ebay.com/45-PCS-LARGE-TAP-DIE-SET-TUNGSTEN-STEEL-TOOL-METRIC_W0QQitemZ400008597513QQihZ027QQcategoryZ58227QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Link to comment Share on other sites More sharing options...
subaru360 Posted March 8, 2009 Share Posted March 8, 2009 To fix the threads, just file/grind down the mushroomed part and run a die down it to fix the threads. Link to comment Share on other sites More sharing options...
Kostamojen Posted March 9, 2009 Author Share Posted March 9, 2009 This one isn`t too pricey.Looks like it has your size.Should be able to buy just one thru a local jobber too.http://cgi.ebay.com/45-PCS-LARGE-TAP-DIE-SET-TUNGSTEN-STEEL-TOOL-METRIC_W0QQitemZ400008597513QQihZ027QQcategoryZ58227QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Oooh. If nobody at work has a set i can borrow, ill have to pick that up Link to comment Share on other sites More sharing options...
Kostamojen Posted March 9, 2009 Author Share Posted March 9, 2009 Oh, on a side note, I've been trying to reassemble my rear brakes today and i've found all the parts I picked up that were supposedly for the FF-1 (rear brake linings, brake cylinder, brake spring kit, etc.) all are wrong I figure its because the suspension is actually a Wagon rear suspension and not a sedan rear suspension, which means all that stuff isn't compatible... Link to comment Share on other sites More sharing options...
bratman18 Posted March 9, 2009 Share Posted March 9, 2009 Oh, on a side note, I've been trying to reassemble my rear brakes today and i've found all the parts I picked up that were supposedly for the FF-1 (rear brake linings, brake cylinder, brake spring kit, etc.) all are wrong I figure its because the suspension is actually a Wagon rear suspension and not a sedan rear suspension, which means all that stuff isn't compatible... Man that sucks!! So is the right stuff available? Where can you find it? Link to comment Share on other sites More sharing options...
Kostamojen Posted March 9, 2009 Author Share Posted March 9, 2009 I just found some wheel cylinders on ebay that look correct. Apparently the ones I bought before were for the front (so I have 4 fronts, no rears). I've found the pins and springs for the brakes now, although one of the springs is not availible anymore, the other still is. However, brake shoes for these rears are non-existent (part number: 625301150 or 625300140) Link to comment Share on other sites More sharing options...
naru Posted March 9, 2009 Share Posted March 9, 2009 These any good? http://cgi.ebay.com.au/Brake-Shoe-Set-to-suit-Subaru-FF-Rear_W0QQitemZ280271313693QQihZ018QQcategoryZ42605QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262 Link to comment Share on other sites More sharing options...
Kostamojen Posted March 9, 2009 Author Share Posted March 9, 2009 These any good?http://cgi.ebay.com.au/Brake-Shoe-Set-to-suit-Subaru-FF-Rear_W0QQitemZ280271313693QQihZ018QQcategoryZ42605QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262 If that picture is correct... Nope. And they need to be "wagon" ff-1 rear brakes. The coupes/sedans are wrong. Link to comment Share on other sites More sharing options...
naru Posted March 9, 2009 Share Posted March 9, 2009 If that picture is correct... Nope. And they need to be "wagon" ff-1 rear brakes. The coupes/sedans are wrong. Looks like he uses the same picture for many shoe sets.Bet he has what you need. Link to comment Share on other sites More sharing options...
moosens Posted March 9, 2009 Share Posted March 9, 2009 I might have those brake parts but don't hold your breath. Link to comment Share on other sites More sharing options...
tailgatewagon Posted March 9, 2009 Share Posted March 9, 2009 find a shop that relines brake pads and have them do it for you specail. its not that bad price wise(i have to do this on my 73 with drums up front) anyway you might look down that road. Link to comment Share on other sites More sharing options...
XT6 Magic Posted March 9, 2009 Share Posted March 9, 2009 Sorry the Snap-On link didn't work. Here is a picture of it from the site (seems to be working now). Link to comment Share on other sites More sharing options...
Kostamojen Posted March 9, 2009 Author Share Posted March 9, 2009 find a shop that relines brake pads and have them do it for you special. its not that bad price wise(i have to do this on my 73 with drums up front) anyway you might look down that road. The linings are OK right now thickness wise, but I am concerned about down the road if I ever have to replace them... I'll probably have to go that route (unless someone like moosens has a pair laying around, or I can find some off of a parts car) Link to comment Share on other sites More sharing options...
naru Posted March 9, 2009 Share Posted March 9, 2009 I just found some wheel cylinders on ebay that look correct. Apparently the ones I bought before were for the front (so I have 4 fronts, no rears). I've found the pins and springs for the brakes now, although one of the springs is not availible anymore, the other still is. However, brake shoes for these rears are non-existent (part number: 625301150 or 625300140) Might be incorrect,but, 1st Subaru says both of those numbers are still good. $19/set https://www.1stsubaruparts.com/part_number.html Link to comment Share on other sites More sharing options...
Kostamojen Posted March 10, 2009 Author Share Posted March 10, 2009 Might be incorrect,but, 1st Subaru says both of those numbers are still good. $19/sethttps://www.1stsubaruparts.com/part_number.html The numbers are still good, but they are not "active" and not availible. If I tried to order them, they will just be canceled (I work at a Subaru parts department FYI) Link to comment Share on other sites More sharing options...
Kostamojen Posted March 10, 2009 Author Share Posted March 10, 2009 I got the tie rod threads fixed today My shop foreman had a whole die set, and another tech gave me a hand, got it done nicely However, I did discover one of the front wheel bearings is shot :-\ Luckily I have a spare, and the tools and help to do the job! Link to comment Share on other sites More sharing options...
Kostamojen Posted March 12, 2009 Author Share Posted March 12, 2009 Thought you guys might find these photos interesting I found last night on a JDM blog: http://minkara.carview.co.jp/userid/215699/car/105463/profile.aspx yes, those are HID's! He shows how to install them in the blog, lol! those are the SSR wheels I saw recently for sale on the yahoo auctions check out his awesome exhaust setup! LOL! Neon green with funky black painted hood... ...but check out his seat setup, I think i'll do something similar. Link to comment Share on other sites More sharing options...
kiwi subbie Posted March 13, 2009 Share Posted March 13, 2009 That Exhaust looks Just like the Factory sports exhaust I have on my GSR Link to comment Share on other sites More sharing options...
Kostamojen Posted March 15, 2009 Author Share Posted March 15, 2009 Small update: I just rolled the front fenders, repaired a bend on the passenger door (got a set of bodywork hammer/dolly's from Harbor Freight), and reinstalled the brake shoes on one of the rear brakes after rebuilding the original brake cylinders (I have one that needs a stud tapped though since it broke off, I basically re-used the original housing but used the internals from some of the "rebuilt" cylinders I found on ebay). I have decided I need to buy my tires before the end of the month, the sales tax is going up next month here in California! I haven't found a place to repair the wheels yet, it looks like I'll have to go with the expensive "mobile repair" wheel specialist... Link to comment Share on other sites More sharing options...
