Kostamojen Posted September 28, 2007 Author Share Posted September 28, 2007 Day 3 Alright, I had an hour or so with nothing to do so I lowered the back, adjusted the ride height so the wheels would fit in the back, and put the front wheels on... I decided to leave it up so I could take some photos and clean underneeth later. Ill take pics this weekend with it on the ground completely. So here are some good pics of the front suspension as it is, along with underneeth the front of the car. Its quite complicated compaired to Macphereson setups isnt it! Link to comment Share on other sites More sharing options...
Kostamojen Posted September 28, 2007 Author Share Posted September 28, 2007 In case anyone is curious about the front suspension... This is from the FSM: Link to comment Share on other sites More sharing options...
Kostamojen Posted September 28, 2007 Author Share Posted September 28, 2007 Warning my Photobucket account might go down tonight due to bandwidth... It will reset on the 29th though. Link to comment Share on other sites More sharing options...
maudsland Posted September 28, 2007 Share Posted September 28, 2007 The FF1 has a great front end, fully adyustable for castor and camber as well as ride high, only problem i had was finding replacement front shockers. Thierry Link to comment Share on other sites More sharing options...
maudsland Posted September 28, 2007 Share Posted September 28, 2007 But of trivia if you want to know, when designing the FF1, Subaru with TKM bearing designed the CV joint that we have and know today, prior to this all front drive cars used a uni joint. Also if you ever get the chance to study the FF1, the car was not designed by car makers but by aircraft engineerers, i had my cars low flying a few time, had a guy on a motorbike followiung me once and said he say the underneath of my car as it went over a hump in the road. Just wanted to let you know Link to comment Share on other sites More sharing options...
Kostamojen Posted September 28, 2007 Author Share Posted September 28, 2007 The FF1 has a great front end, fully adyustable for castor and camber as well as ride high, only problem i had was finding replacement front shockers.Thierry Shouldnt be much of a problem, they are a pretty generic design. I found a recent photo of an FF-1 with the front shocks replaced. The rears shouldnt be difficult either, they might even be simular to other 70's model Subarus. What I'm REALLY concerned about replacing are all the completely worn out bushings that need replacing, and the ball joints on the tie rods... Link to comment Share on other sites More sharing options...
Leeroy Posted September 28, 2007 Share Posted September 28, 2007 But of trivia if you want to know, when designing the FF1, Subaru with TKM bearing designed the CV joint that we have and know today, prior to this all front drive cars used a uni joint. Sorry maudsland but I must disagree. Subaru certainly helped with the development of the 'Japanese' CV joint but it was the 1959 BMC Mini that used the first 'modern' CV joints. All modern CV joints are based on the same design (by Alfred H. Rzeppa in 1928 who worked for Ford in the US) Link to comment Share on other sites More sharing options...
maudsland Posted September 28, 2007 Share Posted September 28, 2007 Here are some part numbers that might get you going; lower BJ assembly: 6232 20011 boot : 6232 07021 clip : 6232 08021 upper BJ assembly: 6232 20001 boot : 6232 07021 clip : 6232 08021 Tie rod assembly rh: 6315 00000 boot : 6315 04000 clip : 6315 08010 Tie rod assembly lh: 6315 00010 boot : 6315 04000 clip : 6315 08010 couple of days ago i saw those parts forsale in yahoo japan but i can't seem to locate them now, i think they ran there time because it was near the top of the list when i saw them Cheer Thierry Link to comment Share on other sites More sharing options...
Kostamojen Posted September 28, 2007 Author Share Posted September 28, 2007 Here are some part numbers that might get you going;boot : 6315 04000 Woot!!! Those are still availible! All the other part numbers are showing "obsolete" but they are still valid... New valid part number for the boot: 731335000 Link to comment Share on other sites More sharing options...
Kostamojen Posted September 28, 2007 Author Share Posted September 28, 2007 Oooh, I just got the part numbers for new locks... Trunk = 651694110 RH door = 651693080 LH door = 651693090 Ignition = 651699010 Link to comment Share on other sites More sharing options...
Kostamojen Posted September 28, 2007 Author Share Posted September 28, 2007 Crap, only the ignition is still active Link to comment Share on other sites More sharing options...
carfreak85 Posted September 29, 2007 Share Posted September 29, 2007 Crap, only the ignition is still active Better than nothing though! Link to comment Share on other sites More sharing options...
Subieguy Posted September 29, 2007 Share Posted September 29, 2007 Man that is going to be a tough one to find parts for. Good luck! Link to comment Share on other sites More sharing options...
Kostamojen Posted September 29, 2007 Author Share Posted September 29, 2007 Day 4: Well I spent today cleaning up the engine bay and under the engine bay with water, simple green, and some brake cleaner... I also washed the car for the first time, and removed the "P.O.S." painted on the trunk. I lowered it onto all four wheels finally too... The fronts clear fine so far, but the rears once someone gets in the car hit the fenders... Anyway, heres some pics from today! Link to comment Share on other sites More sharing options...
moosens Posted September 30, 2007 Share Posted September 30, 2007 Thrilling!!!!!!!!!!!! Hey,I'm pretty sure I have those fabric wrapped hoses for you. Oh man,thanks for posting those "clean" shots. As soon as I can get this current parking vs. cars issue overwith and caught up on the windshield gasket and parts shipping I'm going to focus on getting to the boxes with ff-1 parts out of storage and begin to help make this resto happen. Unfortunately I couldn't make it up to Charlie's this weekend,but that ff-1 will be there,don't worry. And I'll get every solid piece there is for you. Did I mention the ff-1 dashboard? ........uncracked. Charlie freakin' rules ! Link to comment Share on other sites More sharing options...
Caboobaroo Posted September 30, 2007 Share Posted September 30, 2007 Looks awesome man. You could see about rolling the fenders a bit to help with clearance issues and get some stiffer shocks for it to help with how low the car gets when people get into it. Looks like it cleaned up real nice and I can't wait to see how this turns out! Link to comment Share on other sites More sharing options...
Kostamojen Posted September 30, 2007 Author Share Posted September 30, 2007 Did I mention the ff-1 dashboard? ........uncracked. :eek: Oh, and ill be posting more photos shortly... Did some work with the rear seat area, including removing the rear seats, the crappy rear carpet, and the seatbelts... Link to comment Share on other sites More sharing options...
Kostamojen Posted September 30, 2007 Author Share Posted September 30, 2007 Day 5: So today I didnt have much time to work, but I managed to get the rotten rear seats out and vacuum up back there... Didnt take much time or work, but it did give me a MUCH clearer idea of what i'm working with.. For reference, this car doesnt seem to have frame rails. And that black cover on the rear seat is the top of the gas tank. That rear strut-bar looking thing is basically just a seat brace. VERY different chassis from most modern cars. As you can see, the floor board definatly has to go. I'm not sure what to do about that yet, I need to get in contact with some sort of restoration shop in order to deal with the bodywork this car needs... Anyone have any local references in my area??? (Sacramento, CA) Anyway, heres the pics... Link to comment Share on other sites More sharing options...
Subieguy Posted October 1, 2007 Share Posted October 1, 2007 You better get over to ebay. There is a guy selling NOS parts and I saw at least 1 turn signal lens for that car there. It was a front one though. Guy has 35 things for sale. I imagine Paul could probably identify the part number as to what they got to. I will just give you a link instead:http://cgi.ebay.com/ebaymotors/Subaru-68-69-70-71-72-Amber-Marker-Lens-NOS-NEW-Star_W0QQitemZ180165140679QQihZ008QQcategoryZ10076QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Link to comment Share on other sites More sharing options...
Kostamojen Posted October 1, 2007 Author Share Posted October 1, 2007 BTW, I just put this diagram together using the FSM showing how the body is constructed... Link to comment Share on other sites More sharing options...
Kostamojen Posted October 1, 2007 Author Share Posted October 1, 2007 You better get over to ebay. There is a guy selling NOS parts and I saw at least 1 turn signal lens for that car there. It was a front one though. Guy has 35 things for sale. I imagine Paul could probably identify the part number as to what they got to. I will just give you a link instead:http://cgi.ebay.com/ebaymotors/Subaru-68-69-70-71-72-Amber-Marker-Lens-NOS-NEW-Star_W0QQitemZ180165140679QQihZ008QQcategoryZ10076QQssPageNameZWDVWQQrdZ1QQcmdZViewItem $27 + $7 for a lense? Thats more than the original MSRP for it! (FYI, it shows that part number as still active). I cant find the other FF-1 stuff he has listed though... Link to comment Share on other sites More sharing options...
Subieguy Posted October 1, 2007 Share Posted October 1, 2007 Wasn't sure if he had other stuff for a FF-1. I just looked at his sellers list and he had 35 NOS Subaru parts for sale. Link to comment Share on other sites More sharing options...
Kostamojen Posted October 1, 2007 Author Share Posted October 1, 2007 The only thing I found was that lense and the turn signal stalk which i'm not sure is the right one even... However, I did just find this... http://cgi.ebay.com/SUBARU-1000-FF1-FRONT-TURN-SIGNAL-LIGHT-RIGHT-SIDE-JDM_W0QQitemZ140138986580QQihZ004QQcategoryZ50142QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Link to comment Share on other sites More sharing options...
moosens Posted October 2, 2007 Share Posted October 2, 2007 He's got some nice items there but not much that I don't have. Prices are a little steep. I have those signal lenses new as well. Link to comment Share on other sites More sharing options...
Subieguy Posted October 2, 2007 Share Posted October 2, 2007 Hey Paul, Can you tell what all that stuff is for? Link to comment Share on other sites More sharing options...
