TheBush Posted September 25, 2007 Share Posted September 25, 2007 What kind of gas is suppose to go in an ea82t engine? Premium? 87,89? What octane? Link to comment Share on other sites More sharing options...
GlTurbo1987 Posted September 25, 2007 Share Posted September 25, 2007 im pretty sure the owner's manual in my gl says 87.... not 100%, but im pretty sure Link to comment Share on other sites More sharing options...
mikeshoup Posted September 25, 2007 Share Posted September 25, 2007 I run my EA Turbo off of regular (which is 85 octane at this elevation). No problems at all. Try regular, if it pings, then run premium. Link to comment Share on other sites More sharing options...
daeron Posted September 25, 2007 Share Posted September 25, 2007 I run my EA Turbo off of regular (which is 85 octane at this elevation). No problems at all. Try regular, if it pings, then run premium. +1. the most succint piece of advice on "what octane should I run?" is this: Any internal combustion engine should run on the lowest octane fuel it can without detonating. Not that anyone would blame you for running high test when you didnt really NEED to.. but if others run on low test fine, then you should be able to as well. Link to comment Share on other sites More sharing options...
TheBush Posted September 25, 2007 Author Share Posted September 25, 2007 Yeah...I just put Shell V-Power in it, because I think the engine will like me more for now, but will probably just use 87, maybe 89.... Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted September 25, 2007 Share Posted September 25, 2007 I ran 91 in my EA82T at all times. Anything less and it ran like crap. I didnt read a book or look for decals. I just used common knowledge. Turbo's require higher octane to prevent predetonation. If you don't have an intercooler I wouldnt recommend 85 or 87. Even if you do have an intercooler, spend the extra $0.10 a gal and get 91. -Brian Link to comment Share on other sites More sharing options...
Sonicfrog Posted September 25, 2007 Share Posted September 25, 2007 87 regular. Signed: Murphy, the $500 87 T-Wag! Link to comment Share on other sites More sharing options...
calebz Posted September 26, 2007 Share Posted September 26, 2007 Every turbo car I have owned has gotten better mileage and better performance with higher octane. 93 Link to comment Share on other sites More sharing options...
mikeshoup Posted September 27, 2007 Share Posted September 27, 2007 If you get anything from this thread, try what works best for you. My EA81T (granted, not an EA82T, but still has same compression, same turbo...) gets the same power and same mileage on 85 oct or 91 oct. It could very well have to do with the fact I live at 6500ft, and almost never go below 5000ft in elevation. My suggestion, try a couple tanks of premium. Calculate the gas mileage. Try a couple tanks of regular, listen carefully for detonation, and calculate the gas mileage. You can figure the rest out. FYI: The manual says 87 octane. Link to comment Share on other sites More sharing options...
Petersubaru Posted September 27, 2007 Share Posted September 27, 2007 the 1986 turbo (canadian) automatic with original manual says 89, but for my driving style I use 87...timed to 25 deg btdc..no pinging unless I "floor it" Link to comment Share on other sites More sharing options...
4WDFrenzy Posted September 27, 2007 Share Posted September 27, 2007 I ran nothing but 93 in my GL-10 and I have an intercooler, fenderwell intake, and adjustable FPR. I completely agree with Caleb and Brian. It is always a good rule of thumb to run premium or the highest octane available(I'm not talking about 110 octane race gas, for those of you who have it readily available;) ) in you area. It prevents pre-detonation(aka "ping"), which is a killer of turbocharged engines, especially modified ones. Patrick Link to comment Share on other sites More sharing options...
sub_speed_559 Posted October 10, 2007 Share Posted October 10, 2007 i have been running 91 in my 88 turbo wagon with a wrx top mount, but i have detonation problems once i get into higher revs in 3rd-5th gear.....its not just knocks its full on to where my car just nose dives for a sec and then starts to drive normal again.....for some reason my manual says 90 octane or higher but iono....i think that my detonation problem could be in part to the fact i redid my head set but had the typical cracks across the valves on both of my heads, i think that this is my hot spot and is the main cause for the detonation problems...... Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 10, 2007 Share Posted October 10, 2007 Check your timing. I believe I had mine set at 22 degree's in the RX with no problems. Any higher and I got horrible pinging. -Brian Link to comment Share on other sites More sharing options...
4WDFrenzy Posted October 10, 2007 Share Posted October 10, 2007 Sub Speed 559, it sounds like your timing may be way too far advanced. Let me ask this before I jump to conclusions about what is wrong with your car, how much boost are you running? Also, what rpm are you wringing it out to before you shift? Some of the old school sube's won't take more than between 10-12 psi before they start hitting fuel cut. Others(the lucky one's) can go well over 12psi with no inherent fuel cut problems. If you have your boost turned up too high, this could be the problem. Patrick Link to comment Share on other sites More sharing options...
robm Posted October 11, 2007 Share Posted October 11, 2007 Sorry I am so fussy, but let's get the terms right: THERE IS NO PREDETONATION! There is preignition, when the charge goes off before the spark hits. There is detonation, when the charge burns faster than it should, after the spark. This is also called "knock." Low octane ping is a sign of detonation. http://en.wikipedia.org/wiki/Engine_knocking#Pre-ignition Link to comment Share on other sites More sharing options...
beataru Posted October 12, 2007 Share Posted October 12, 2007 WHATEVER ROBM.... lol just kidding, anyways... my fuel lid says use premium fuel only... whatever that means and every time i fill it up I tell it "no premium untill you make power" so far the negotiations are at a standstill. Link to comment Share on other sites More sharing options...
Myxalplyx Posted October 12, 2007 Share Posted October 12, 2007 Use what the owners manual says to use. If it pings, use the next higher octane. I used 93 octane because I was wuss and didn't want to try and wait to hear ping, detontation, etc on a lower grade octane. Also, I remember that thread that was posted with the inlet temperature of a non-intercooled EA82T. I loved that thread and the numbers. Hot air is not good. I thought of cylinders #1 and #3 overheating and the cooling system problems people have had over the years. I thought of headgaskets going bad and leaking. Using 93 octane gave me a warm, fuzzy feeling inside, even when it was intercooled. Car ran great even though the body went all to hell. Hrrm...I think that is all. :cool: Link to comment Share on other sites More sharing options...
Jub Nub Posted October 12, 2007 Share Posted October 12, 2007 i use 91 octane also. anything else runs like crap, pings. but then, i have the high compression bottom end with no intercooler... maybe i should get one.... Link to comment Share on other sites More sharing options...
Myxalplyx Posted October 12, 2007 Share Posted October 12, 2007 i use 91 octane also. anything else runs like crap, pings. but then, i have the high compression bottom end with no intercooler... maybe i should get one.... Not to go to far off topic but maybe this link will convince you to get an intercooler installed (Especially being higher compressioned and all). http://www.ultimatesubaru.org/forum/showthread.php?t=15554&highlight=inlet+temp Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 12, 2007 Share Posted October 12, 2007 Definatly if you are running a high comp block, get an intercooler! The Saab 900 IC is almost a direct bolt in: The inlet and outlet are both 2 3/8" outside diameter, which is the same size as the intake manifolds outside diameter. The difference with and without are night and day. -Brian Link to comment Share on other sites More sharing options...
Myxalplyx Posted October 13, 2007 Share Posted October 13, 2007 Definatly if you are running a high comp block, get an intercooler! The Saab 900 IC is almost a direct bolt in:The difference with and without are night and day. -Brian Brian, That is a beautiful setup. Seems like the car should have came like that from the factory. Would be nice to see someone sell that as a kit. The brackets that stand the intercooler up is sweet. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 13, 2007 Share Posted October 13, 2007 Yeah it worked out quite well. Turbohoses.com sells the silicone couplers, and I bought two 180 degree mandrel bent U bends in 2 3/8" inside diameter, then cut them both in half to give me four 90 degree bends. The brackets were just angle and strap I got from Home Depot. The hardest part was adapting the turbo outlet which is 1 3/4" outside diameter i believe. Sure wish the intercooler install on my Legacy was that neat and easy -Brian Link to comment Share on other sites More sharing options...
4WDFrenzy Posted October 13, 2007 Share Posted October 13, 2007 Sorry I am so fussy, but let's get the terms right: THERE IS NO PREDETONATION! There is preignition, when the charge goes off before the spark hits. There is detonation, when the charge burns faster than it should, after the spark. This is also called "knock." Low octane ping is a sign of detonation. http://en.wikipedia.org/wiki/Engine_knocking#Pre-ignition Wooo! My bad man! You don't have to be so grouchy about it. I was thinking the words pre-ignition and the other word for it detonation, then wound up typing pre-detonation. No need to blow a gasket over it. Besides, unless you are contributing something to the topic at hand, you might think twice about posting, or at least just say nicely,"Hey, you may have misspelled something. It is pre-ignition, not pre-detonation." Geez............. Anyway, an intercooler on these engines is the way to go. You increase the engine reliability greatly with one. Your engine will Thank You for it! Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 13, 2007 Share Posted October 13, 2007 I dont care what Wikipedia has to say about it. Im still going to refer to it as predetonation. -Brian Link to comment Share on other sites More sharing options...
