SubaruJawn Posted September 30, 2007 Share Posted September 30, 2007 how would i give my XT6 better gear ratio? stock 3.9 how about 4.11 ? or higher Link to comment Share on other sites More sharing options...
Phizinza Posted October 1, 2007 Share Posted October 1, 2007 Manual is it? FT4WD? You'll find the FT4WD boxs only came in 3.7 and 3.9. And because of the design of the centre diff and pinion shaft you can only use those ratios unless you cut, weld, temper a different pinion gear on. Link to comment Share on other sites More sharing options...
SubaruJawn Posted October 1, 2007 Author Share Posted October 1, 2007 Fulltime AWD 5 spd manual. Link to comment Share on other sites More sharing options...
Numbchux Posted October 1, 2007 Share Posted October 1, 2007 as phiz said, FT4WD boxes only came with 3.7 or 3.9.only way to change that, is to change the center diff to a new-gen AWD center, and then you can use an EJ-series 4.111 or 4.444 front ring and pinion. it's no small task....that's for sure! Link to comment Share on other sites More sharing options...
idosubaru Posted October 1, 2007 Share Posted October 1, 2007 EJ swap. Link to comment Share on other sites More sharing options...
Phizinza Posted October 2, 2007 Share Posted October 2, 2007 Yes, I have to agree. If it ain't D/R or you don't want D/R then the EJ box is the way to go. There is a guy here in Aus who spoke to me over email or PM or something that is getting a 4.11 or 4.44 (forgot which one) pinion gear put on a FT4WD 3.7 ratio pinion shaft... Should be interesting if it works out. Link to comment Share on other sites More sharing options...
SubaruJawn Posted October 2, 2007 Author Share Posted October 2, 2007 145 hp 5spd at 4.11 gear ratio. my xt6 will fly ! dont you think? Link to comment Share on other sites More sharing options...
mikeshoup Posted October 2, 2007 Share Posted October 2, 2007 Yeah, 'cept you won't get an EJ transmission to bolt up to an EA/ER engine. Link to comment Share on other sites More sharing options...
SubaruJawn Posted October 2, 2007 Author Share Posted October 2, 2007 Yeah, 'cept you won't get an EJ transmission to bolt up to an EA/ER engine. oh i cant put an ER27 on a legacy transmission?. tarter sauce! i want my xt6 to move faster Link to comment Share on other sites More sharing options...
joostvdw Posted October 2, 2007 Share Posted October 2, 2007 oh i cant put an ER27 on a legacy transmission?. tarter sauce! i want my xt6 to move faster a transmission with higher gear ratios is not going to make your six any faster. you'll still have the same power, you're just trading top speed for acceleration. the guys at FHI knew what they were doing when they gave these ratios to the corresponding cars, as long as you don't make any drastic changes (or need lower gears for offroad use) just stay with the stock ratios, not worth the hassle to change it all Link to comment Share on other sites More sharing options...
SubaruJawn Posted October 2, 2007 Author Share Posted October 2, 2007 ok. i guess i'll keep it the same. Link to comment Share on other sites More sharing options...
joostvdw Posted October 2, 2007 Share Posted October 2, 2007 don't get me wrong, if you're going to swap engines/trannys anyway you might as well get the ratio you want, it's just not worth it to do all this effort for not so much result. all just my opinion, if you want to go for it, be my guest Link to comment Share on other sites More sharing options...
Numbchux Posted October 2, 2007 Share Posted October 2, 2007 3.9->4.111 change is pretty small, in all reality. an RX FT4WD D/R basically allows you to switch from 3.70 -> 4.444 on the fly, and you really only notice that in the higher gears, where it just gives you short freeway legs. Link to comment Share on other sites More sharing options...
kingbobdole Posted October 4, 2007 Share Posted October 4, 2007 3.9->4.111 change is pretty small, in all reality. an RX FT4WD D/R basically allows you to switch from 3.70 -> 4.444 on the fly, and you really only notice that in the higher gears, where it just gives you short freeway legs. +1 Rick once noticed that I was in Lo in my Rx and was surprised... It just doesn't even feel any different. I did an EJ engine swap and now it IS faster:banana: Link to comment Share on other sites More sharing options...
Myxalplyx Posted October 13, 2007 Share Posted October 13, 2007 Yes, I have to agree. If it ain't D/R or you don't want D/R then the EJ box is the way to go. There is a guy here in Aus who spoke to me over email or PM or something that is getting a 4.11 or 4.44 (forgot which one) pinion gear put on a FT4WD 3.7 ratio pinion shaft... Should be interesting if it works out. I was trying to have this same thing done on my XT6. I have the 4.44 gears for the front and the rear. Was talking to TomsSVX on the SVX board to do the hookup for me since I do not know how. I just need it installed. I a ready to go. I KNOW the car will be faster. Here's what I posted at the XT6 site. *Added for personal reference* Gear ratio torque "What many car enthusiasts don't know, or simply overlook, is that you can get more performance out of the power you already have. Power (more accurately, torque) is never delivered directly from the flywheel to the pavement, without first being multiplied by gear ratios in the transmission and differential. The math is pretty simple: A car with a 4.0:1 gear ratio puts 33% more torque to the wheels than a car with a 3.0:1 gear ratio with no increase in engine torque. "My estimates using above 33%---> 3.70 to 4.11 = 16.5% more torque 3.70 to 4.44 = 23% more torque I am going to keep a close eye on this thread. (Headed to the garage 1:57am in the morning to scavenge the 4.44 parts). Link to comment Share on other sites More sharing options...
idosubaru Posted October 13, 2007 Share Posted October 13, 2007 Anyone able to do the swap? we'll just hijack subex's thread since he doesn't need it anymore! you can't find a shop around there to do it? you want 4.44 gears in an AWD automatic right? are they going in your transmission with the modified valve body? Link to comment Share on other sites More sharing options...
Myxalplyx Posted October 13, 2007 Share Posted October 13, 2007 we'll just hijack subex's thread since he doesn't need it anymore! you can't find a shop around there to do it? you want 4.44 gears in an AWD automatic right? are they going in your transmission with the modified valve body? Gary! Me no hijacker...just over-excited that someone else was thinking of doing this. I would like to see him go through with it...or even you. Haven't tried looking for a shop again. Big YES for 4.44 gears in AWD automatic. Yes, going in tranny with modified valve body (or so the shop said anyways). What do you got cooking in your brain Gary? And why are you awake so late? BTW: Just got back up from the basement scavenging for parts. Found these--> Is this all that is needed for a 4.44 swap? If so..Subex..at least you know what you need to do. I'm ready like...yesterday. I provided the little calculation above to give Subex an idea on what he could expect with the swap/upgrade if he were to do it. Also Subex, I have read stories that it would help but am not sure. I would gladly be a guinea pig though. Just hate sitting around wondering how things would be. Life is short. Are you going to go ahead with the swap/upgrade? Don't give up that easy. These 'little' things add up. Link to comment Share on other sites More sharing options...
idosubaru Posted October 13, 2007 Share Posted October 13, 2007 subex won't be doing this (anytime soon at least), he was hoping there was an easy way to do it. i've never touched a diff before so i wouldn't want to do it. i have a spare transmission and was thinking i could have it rebuilt with your gears (you ship me the gears). but that's pointless as you'll want to keep your valve bodies. the price woudln't be anything spectacular, but the shop is a highly respected trans shop in my home town (where you came to my place). i imagine you can find something in your area. i may be pulling two of mine apart. i'm swapping transmissions in my XT6 and am thinking about putting an LSD in my front differential before i drop the transmission in. i haven't found any reliable LSD's i'm comfortable with but i'm almost positive EJ series front diffs interchange with the XT6 so im' still considering it. i may take an XT6 and EJ front diff apart to compare and have parts, but i'll have a shop install the LSD and make the final adjustments. if that's the case i'll definitely be finding a shop to work with and will let you know who i come up with and what the costs are. Link to comment Share on other sites More sharing options...
idosubaru Posted October 13, 2007 Share Posted October 13, 2007 Is this all that is needed for a 4.44 swap?looks like it to me, so long as the XT6 rear axles fit that rear EJ diff. looks like there aren't any stub axles on the rear diff? do they just pop back in or is that a different set up? Link to comment Share on other sites More sharing options...
Myxalplyx Posted October 13, 2007 Share Posted October 13, 2007 do they just pop back in or is that a different set up? Not sure Gary! This is foreign territory for me. Link to comment Share on other sites More sharing options...
idosubaru Posted October 13, 2007 Share Posted October 13, 2007 And why are you awake so late? hey, we're in the same time zone freaky!! i was talking/socializing all evening so now i'm getting a bit of work/studying done. you know.....i'm turning in right now. Link to comment Share on other sites More sharing options...
SubaruJawn Posted October 14, 2007 Author Share Posted October 14, 2007 No I Want to do it to a AWD 5 Speed Manual XT6. and Gary Pretty much knows me like a book. he understands what i want. i just wish women could also:lol: . could i do it with a manual?. 23% more torque !! NICE 4.44 gear ratio in an XT6 Link to comment Share on other sites More sharing options...
Myxalplyx Posted November 3, 2007 Share Posted November 3, 2007 So Subex!! Are you going to go ahead with this project? Link to comment Share on other sites More sharing options...
SubaruJawn Posted November 3, 2007 Author Share Posted November 3, 2007 I Dunno. i may i may not. as for right now no. winter is begining and dont have suitable place to do it. (heated place) Link to comment Share on other sites More sharing options...
SubaruJawn Posted February 21, 2008 Author Share Posted February 21, 2008 heres my old post Link to comment Share on other sites More sharing options...
