Ea81t as core for n/a rebuild
Ive got a line on a core motor for my brat. Its an ea81t minus the turbo and F.I. stuff. After some resurch here I now know that it is lower compression. Is this a property of the heads or the shape of the pistons? What other differences does this motor have from the n/a ea81. Can I still use it as a core or should I have said no?
I missed out, Chris Lantieri was giving one away a few months ago :(
I want to build a motor for my brat with out removing my current running motor.
-Sam
Different cam, pistons, heads, and entire intake/turbo ect. The block is the same as any other hydro lifter EA81 block.
Mounting the turbo in it's stock config would require the turbo engine cross-member, all the wireing, the ECU, intake, turbo, and all the exhaust bits. Also have to convert the existing fuel system to high pressure for the fuel injection.
Or you could do a carbed turbo and make it all custom - but that's never been done that I know of, and would require a lot of old-school turbo knowledge that few people have now.
I dont have the motor yet, and Im not going to get it if I cannot use it, if anyone in Vegas area can use it and would like to swap let me know.
Kinda a bummer cause the damn junkyard wants $270 for a core. And this one would have been free.
-Sam
So my unit doesnt have hydro lifters?
1982 brat
Thanks
-Sam
No. Hydro lifters came on 83/84 automatics, and all 85+ EA81's. All others were solid lifter and require adjustment every 15,000 miles.
In addition, pre-83 engines also had smaller intake valves so the heads don't flow as well.
You could use that block just fine, as long as you replaced the pistons with N/A pistons.
I think the EA82's have the same stroke and bore as the EA81, so it maybe possible to use EA82 pistons as well.
The heads are different, and the pistons are different. The intake manifold is also different.
If you get the motor and want to get rid of the heads, let me know. I have been looking for a set of (uncracked!!) heads for a long time. If you were closer, i would have a EA81 for you... got one in the garage unused and could use a fresh build. However, Sacramento is alittle far to go to just trade motors.
-Brian
So my ideal builder is a 83+ auto, or 85+ any... Why did the 83+84 only have hydro's in the auto trans model?
Thanks for all the info
-Sam
No one really knows the answer to that.
Depends on what you want - if you want raw N/A power then you want a solid lifter, big intake valve engine - 83/84 manual tranny model. Less drag on the valve train with solid lifters. If you want easy maintenance and quieter valve train noise then you want the hydro's.
In reality either one is fine and the power difference is pretty much negligible between the lifter types. With a Delta cam, EA82 SPFI pistons (9.5:1) and a port and polish you can pull 100 HP out of the EA81 pretty easily using either a Weber or the EA82 SPFI.
