Ma-fia Posted December 9, 2003 Share Posted December 9, 2003 I've just about made my mind to replace my intake manifold gaskets tomorrow. Is there anything I should know? I'm worried about getting dirt into the engine. Any good ways to avoid it? Any tips will be appriciated! Link to comment Share on other sites More sharing options...
archemitis Posted December 9, 2003 Share Posted December 9, 2003 i would take it to the car wash, wrap a bag around the disty, and go to town with the pressure washer, to get all the dirt off the engine. then make sure you drain the coolant system as much as possible to keep the green stuff out of your intake port, when you take the intake off. other than that, just dont strip the bolts out, and maybe use new ones when you put it bak on Link to comment Share on other sites More sharing options...
Ma-fia Posted December 9, 2003 Author Share Posted December 9, 2003 Thanks! I figured I should do something like that; even bought some engine degreaser to hose it down with before I wash the engine. You think that's a good idea? I am still wondering how to scrape off the old gasket without dropping half of it into pistons! Link to comment Share on other sites More sharing options...
electryc_monk Posted December 9, 2003 Share Posted December 9, 2003 Okami and I have 2 engines currently "disassembled" and we can show you the process on a block thats out and on a banch at his place. of course...... you could email me directly and i can give you the phone number over there too. that way the suggestions and sites of the specifics Arc is refering too can be made visually obvious and a little get-together could occur too. Link to comment Share on other sites More sharing options...
archemitis Posted December 9, 2003 Share Posted December 9, 2003 you know, every one i have pulled off, had the gasket stuck to the manifold, and i just use a razor blade. a little paper in the combustion chamber never hurt anybody anyway. and if it wont start, pull the disty cap off and dry it out and squirt some wd 40 in there. Link to comment Share on other sites More sharing options...
