subaruloverbrad Posted December 9, 2003 Share Posted December 9, 2003 I am planning on buying my wife a turbo xt awd auto. It has the ea82t engine, She wants it to be fast, i've never had a turbo roo before, here is the kicker, she wants it lifted with at least 28 inch tires on it, the mechanical parts i can do no problem, it just is i know nothing about turbos and with big tires, i'll have to have more power to still be quick. what can i do to accomplish this? Remember i know nothing about turbos, I thought bov, crank pressure up, what is boost cut out, @ how do you keep it from doing it? everything i need to do to make it quick, links? anything to help me to understand it better. Thanks Brad Link to comment Share on other sites More sharing options...
calebz Posted December 9, 2003 Share Posted December 9, 2003 try this one:D http://usmb.ultimatesubaru.org/forum/search.php?s= Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 9, 2003 Share Posted December 9, 2003 With only 110 HP, even if you modified the engine quite a bit, the problem is that with 28" tires, your gearing won't be right - I'm afraid it will never be fast. Maybe if you drop in an EJ engine. She means acceleration right? That's a tall order with 28" tires man. GD Link to comment Share on other sites More sharing options...
Snowman Posted December 10, 2003 Share Posted December 10, 2003 Does this car have 3.7 axle gears? If so, you could probably swap in 3.9s from a non-turbo manual transmission model. That would help compensate for the larger tires. Link to comment Share on other sites More sharing options...
jethopper Posted December 10, 2003 Share Posted December 10, 2003 Is ist possible to swap the front diff from a non-turbo into an awd box? From what i see in the FSM the pinion shafts are different. Link to comment Share on other sites More sharing options...
Meeky Moose Posted December 10, 2003 Share Posted December 10, 2003 ahh so you were the one who sniped that xt from me off ebay at any rate, ya get fast, or you get big.. in most cases not both.. unless you went with an XT6 that had the flat 6 cylinder engine, much more power for big tires.. me thinks your trying to start an offroader with the wrong platform.. Link to comment Share on other sites More sharing options...
Danbob99 Posted December 10, 2003 Share Posted December 10, 2003 I also have the ea82t in my wagon, and it's a fast car, for what it is i mean, but slap those 28's on there , and your going to need alot more horsepower, or a lot smaller gears to turn those bad boys. Link to comment Share on other sites More sharing options...
subaruloverbrad Posted December 11, 2003 Author Share Posted December 11, 2003 right now i have an 1981 ea81 6 inch lifted subaru wagon, and it accelrates really good. i can usually keep up with the 4x4's at work. I am running 31x10.50x15 tires. with 3.90 rears. stock engine. but anyhow.... the reason i'm using this platform, is she wants an off-road sports car, told her to get an rx but not sporty enough. even though i will be lacking in power, what options do i have to make it as strong as possible? Will an er27 fit in a regular xt? if it would, guess i could turbo it, would stock turbo be big enough? Link to comment Share on other sites More sharing options...
Meeky Moose Posted December 11, 2003 Share Posted December 11, 2003 did ya get that black xt turbo off ebay? if so, it'd be a shame to see that one stripped out and parted for an offroader.. you do know they only made that car for 1/2 a year.... its super rare... and in too nice of shape to see it go... as far as puttin an ER27 (6cyl) in it, you would basically need an entire xt6 for parts, as you'd need the complete wiring harness, ecu, engine, and on down the list.. personally i think you'd be better off finding an xt6 to do your build.. xt6's also had 5-lug hubs, came in fulltime 4wd, and were the same body style.. they also had 145hp and torque compared to the 110 of the ea82T.. Turbos also are not as good for 4x4in cause you gotta keep it spooled up to be of any use, which is hard if your say rock crawling.. if she really wants a sprotscar offroader, the xt6 would be the way to go.. if ya got that black xt off ebay, let me know if you decide to get rid of it for something else.. i have a lifted 84' hatch to trade Link to comment Share on other sites More sharing options...
mudrat79 Posted December 11, 2003 Share Posted December 11, 2003 You can get power and speed out of your car with 28's.... We took a stock EA-82T and Boosted it to 10 psi......also has an intercooler.... Also has 3" Turbo Back exhaust......flow through cat..... Biggest and Most important thing was to swap in a 3:90 ratio 5 speed Hi-Lo tranny out of a Non Turbo car....you will have to get non Turbo axles for the front, but everything else should be bolt in.... Having this trans Allows the turbo to spool much earlier in rpms, giving you gobs more power.....even in the bottom end of engine rpm's I can break this wagon loose, and get side ways on pavement in 4x4...... feel free to call me on it, I'll explain things better to you...... Don't let anyone tell you it can't be done, cause we did it...... later, John in Oregon...... Link to comment Share on other sites More sharing options...
baccaruda Posted December 11, 2003 Share Posted December 11, 2003 if you post a request for custom transmission gears on the http://www.ausubaru.com forum, someone there may be able to help you. i recall some talk about that. Link to comment Share on other sites More sharing options...
subaruloverbrad Posted December 12, 2003 Author Share Posted December 12, 2003 i didnt get the xt off of ebay there are 2 black xt 4 turbos at to car lots here in southern va. has to be auto, she wont learn a man. maybe ill lift it 6 inches and use an seprate transfer case, but she doesnt want me to do that..... she loves the way the xt looks. i can (maybe) get an entire parts xt-6 but it is a man. and no title, but then it would be harder to find parts for and i like the 4-6 lug conversion. and since i have 3 ea81's and 2 ea82's i have enough parts to keep an xt-4 going a while, i think. guess i'll turn up the boost a little, are their any smaller turbos that will fit? a smaller one would spool up faster than a large one (i think). Oh yeah, i'm thinking on installing a 2nd trans in my roo, if it works, i will have pics, kinda cold out side so that project is on hold for now. one xt 4 is $800, the other is $1000, both are neg with cash! both are black, one is auto, both are turbo. also one in johnson city for $200, dont know condition or much about it though. Link to comment Share on other sites More sharing options...
MilesFox Posted December 12, 2003 Share Posted December 12, 2003 get rid of the automatic. swap in a dual range with 3.9 gear and lo range. it will be faster than an automatic, and lo range can give big tires more streetable gearing Link to comment Share on other sites More sharing options...
