calazo Posted October 8, 2007 Share Posted October 8, 2007 Guys, I am about to go for an oil change in my rig. I've been using Mobil 20W-50 which is the generic oil in my neck of the woods (I'm not particularly pleased with the way it performs, though). However, other than the more expensive synthetic motor oils, what kind of oil would you recommend? (I am kinda heavy duty user: 8.000ft above sea level altitude, some mud/dirt roads, lots of hills and heavy on the gas)... Thanks:confused: Link to comment Share on other sites More sharing options...
ericem Posted October 8, 2007 Share Posted October 8, 2007 DINO oil or any synthic really if you don't mind spending hte extra few $$ in 10w-30. If the temperatures are colder like close to freezing then 5w-30. Link to comment Share on other sites More sharing options...
calazo Posted October 8, 2007 Author Share Posted October 8, 2007 Thanks, what about the 15W-40?, I know it is designed for diesel & truck engines, and it is a moderately priced option, but like I said, I need heavy duty oil, and one that can reduce engine clacking noises...:cool: Link to comment Share on other sites More sharing options...
bulwnkl Posted October 8, 2007 Share Posted October 8, 2007 15W40 all-fleet/diesel oil is an excellent choice, as are the 10W30 all-fleet/diesel oils. I'd use either of them over a 20W50. Plus, with your usage conditions, change your air filter VERY often. Link to comment Share on other sites More sharing options...
Rooster2 Posted October 8, 2007 Share Posted October 8, 2007 I don't go out of my way to use Mobil oil lubricants, but I have alway held them to be of high quality. What kind of difficulty have you found with their motor oil, that has you shopping for something else? Link to comment Share on other sites More sharing options...
zstalker Posted October 8, 2007 Share Posted October 8, 2007 diesel oil has a higher content of ZDDP (zinc phosphate). it's a great barrier lubricant, but automotive oil has less and less of it, since it's not terribly friendly to the catalytic converter. it's a great additive to use, but only if you don't really care about the cat, pasing emissions, maintaining the warranty on the cat (extremely expensive). if you want a heavy oil for summer use, there are synthetics (and some conventionals) that go all the way to 20w-50. for more info on oils, search...there are dozens of threads on this forum, or visit http://www.bobistheoilguy.com for some serious oil fanatics and more information about lubrication than you can take in in an entire lifetime. my only advice: don't believe hearsay, rumors or grand claims (positive or negative) without making sure they're true by actual scientific studies. ~Erik~ Link to comment Share on other sites More sharing options...
