SubaruWagon87 Posted October 10, 2007 Share Posted October 10, 2007 I have an 83 dl wagon that a wheel bearing went out in, I put a new one in, but I didn't grease it enough:dead:, so I had a new bad bearing. That same weekend I looked at an 89 coupe, which is what I'm driving now. The 83's been sitting for a couple weeks now, and the more I think about it, the more I think it's fixable. But I want some opinions as to whether I should put the time and money into it, or just part it out. It needs: a windshield left rear wheel bearing brake line (not sure which one, but it's in the rear) gauge cluster 2, possibly 3 axles 2 185/70/r13's (right now its rockin 185's in the rear, and 175's in front) major exhaust leak fixed possibly a different rack and pinion, there's slop where the steering shaft comes down and meets it the heater controls hooked up right misc. interior parts I'd like to: reseal the engine d/r swap (4-speed for now) swap a dash from a gl into it wire up all the gl gauges (if I go that route) change all the plastic interior pieces from said gl so that colors match. I don't know how probable doing all this stuff is, but I'd like to see the 83 on the road again someday. Let me know what you think, I need some advice. Quote Link to comment Share on other sites More sharing options...
daeron Posted October 10, 2007 Share Posted October 10, 2007 get the blue car found here http://www.ultimatesubaru.org/forum/showthread.php?t=80666 in yelm from markjw. Find an EA82 in the boneyard with SPFI and a d/r 5speed. Do it. My strongest advice is, if you CANNOT get a parts car then it probably isn't worth it all in the long run, because all that WILL nickel and dime you pretty bad... restoring an old car is not cheap, even doing a "rough and ready" restore like you are talking about... the only sane and practical way to do it is via a parts car, ESPECIALLY when you start talking about cluster swaps, etc... BUT, the soobie is the car to go with. They are inexpensive and abundant where you are, functional, and economical, and you obviously already have a "thing" for them, so in the end it is your call. Quote Link to comment Share on other sites More sharing options...
subaruguru Posted October 10, 2007 Share Posted October 10, 2007 i havea compleat spfi set up intake,disty,wiring,computer, all in a box. any takers. im stiking with carb for now. hey LJ i found this would be perfect for you with all the parts and all. http://www.ultimatesubaru.org/forum/showthread.php?t=80528 Quote Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted October 10, 2007 Author Share Posted October 10, 2007 I'd like to eventually do a 5-speed swap, but I'm happy with a 4-speed for now. And Robbie, you have me interested in your spfi setup. What all is involved with doing an spfi swap? Quote Link to comment Share on other sites More sharing options...
subaruguru Posted October 10, 2007 Share Posted October 10, 2007 just swap the intake over then put the wiring harness in. its all there and labeled. Quote Link to comment Share on other sites More sharing options...
mikeshoup Posted October 10, 2007 Share Posted October 10, 2007 just swap the intake over then put the wiring harness in. its all there and labeled. Don't forget about swapping in the SPFI Disty. For an EA81, you'll need to swap the drive gear from the EA81 disty to the EA82 disty. General Disorder has a nice write up on this somewhere. Quote Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted October 10, 2007 Author Share Posted October 10, 2007 Don't forget about swapping in the SPFI Disty. For an EA81, you'll need to swap the drive gear from the EA81 disty to the EA82 disty. So alls I'll have to do is put the spfi intake on the ea81 heads, swap the disty (after swapping the gear) and I'm set? Quote Link to comment Share on other sites More sharing options...
hatchsub Posted October 10, 2007 Share Posted October 10, 2007 Need a new fuel pump as well as new fuel lines on top of that. SPFI fuel pump. Quote Link to comment Share on other sites More sharing options...
daeron Posted October 11, 2007 Share Posted October 11, 2007 http://home.comcast.net/~trilinear/EA81_SPFI.html Quote Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted October 11, 2007 Author Share Posted October 11, 2007 http://home.comcast.net/~trilinear/EA81_SPFI.html Wow. That looks complicated. Or that could just be me being a noob. Is an spfi swap worth it? What would I gain with spfi over carbed? Quote Link to comment Share on other sites More sharing options...
subaruguru Posted October 11, 2007 Share Posted October 11, 2007 So alls I'll have to do is put the spfi intake on the ea81 heads, swap the disty (after swapping the gear) and I'm set? it came off an ea81 car so the disty is allready done. and included. along with the compleat engine harnes and computer. oh and the intake maf sensor ya its all there. Quote Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted October 11, 2007 Author Share Posted October 11, 2007 So you have everything needed for the spfi swap? What would you want for it? Quote Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted October 12, 2007 Author Share Posted October 12, 2007 Robbie, how much do you want for it? Also, I've been thinking I might as well go ahead and do a 5-speed swap, since I'm yanking the trans anyway. How involved does that get? I know I need one of Jerry's kit, and don't I need to have my driveline shortened? Quote Link to comment Share on other sites More sharing options...
subaruguru Posted October 13, 2007 Share Posted October 13, 2007 you need jerrys kit a clutch for an 85 suabru gl 4x4 dr. with the 6 springs. then a lengthend driveline 48 inches of new tubing. and of coures the 5 speed duel range. also 100 and the spfi set up is youres. Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted October 13, 2007 Share Posted October 13, 2007 I have a known good d/r 5speed, EA82 flywheel, nearly new clutch, crossmember and linkage for $250. I will be making another run to Cle Elum in a few weeks, once I get a call that my next parts truck is ready. Quote Link to comment Share on other sites More sharing options...
subaruguru Posted October 13, 2007 Share Posted October 13, 2007 damn thats alot for a dr tranny. the most iv ever payed is 75 bucks. Quote Link to comment Share on other sites More sharing options...
4x4_Welder Posted October 13, 2007 Share Posted October 13, 2007 damn thats alot for a dr tranny. the most iv ever payed is 75 bucks. $75 for the tranny, $50 for a flywheel, $130 for a clutch, maybe another $25-30 for the linkage and crossmember from a junkyard- Not overpriced at all, is it? Not to mention this is a known good tranny- Quote Link to comment Share on other sites More sharing options...
SubaruWagon87 Posted October 13, 2007 Author Share Posted October 13, 2007 $75 for the tranny, $50 for a flywheel, $130 for a clutch, maybe another $25-30 for the linkage and crossmember from a junkyard- Not overpriced at all, is it?Not to mention this is a known good tranny- So $100 for the tranny and linkage? Quote Link to comment Share on other sites More sharing options...
