This is a '92 Legacy
So my rear diff was smoking/tight all of a sudden and I changed the oil. It was running okay for a couple of days(a little vibration/grinding) and now it is smoking and tight again. There are no visible wet leaks, and there was a good amount of oil left when I changed it. I didn't see very much metal in the used oil, but like I said, there has been some grinding. Do I have to replace the unit? Is there just a gasket I could replace? And how much will it cost?
Thanks
http://bbs.legacycentral.org/viewtopic.php?p=211571&sid=e48c3ef81a2c5bb471b7f9527f7f5096
This is the link to the writeup on replacing the rear diff. Remember, you may need an alignment when done, unless suspension stuff is marked before it's removed (rear struts don't matter).
EDIT: What a DA I am! I got this confused w/another thread I'm helping on...regardless, here's an interchange chart as it sounds like you'll be replacing your rear diff:
http://bbs.legacycentral.org/viewtopic.php?t=13500&sid=7add370daf15909c801cba58 f69c2cbd
This is for USDM models, so not sure how valid it is for you Int'l guys.
  johnceggleston said:
when removing the rear diff, does the 'front member' have to come out?
I never have???
One tip for removing most Subaru Rear diffs. It actually makes it easier if you don't use PB on the rear nuts. This will sometimes cause the nut to turn the stud out of the case. Then you don't need to slide the whole thing forward 2" to clear the studs.
<< Originally Posted by johnceggleston
when removing the rear diff, does the 'front member' have to come out?>>
I never have???
One tip for removing most Subaru Rear diffs. It actually makes it easier if you don't use PB on the rear nuts. This will sometimes cause the nut to turn the stud out of the case. Then you don't need to slide the whole thing forward 2" to clear the studs.>>
me too. i remember a day i went to a u-pull-it and pulled 4 LSD's out. never once touched a "front member"
  john in KY said:
In my experiences once you can "hear" the differential it is time to replace or rebuild it. I could probably find one locally in the $50 range but who knows wherever you live.
My car has a quiet 'wobba-wobba-wobba' sound when driving over a certain speed. Is failure imminent? :eek:
- Scott
  john in KY said:
Probably not. Drain the lube and look for metal if really concerned. I would suspect the tires if old and worn.
Metal is not an issue if theres some flakes, bear in mind, these things are designed to wear out slowly, very very slowly, so metal in the oils not a huge concearn, however if you got a disco ball show coming out of your diff, meaning, if you drainit and you start to boogie down, youve got issues, after not draining a diff for a long time, it will be close to that but, you should be able to discearn if theres issues from the metal. If I made any sence what so ever :-\ .
