ru4x4ever Posted December 10, 2003 Share Posted December 10, 2003 On my Ea81 wagon my headlights are terrible. they need to be brighter. Soobme knows of a way to re-wire with a relay, but was wondering if anyone knows another way maybe a conversion that wont break the bank or just somthing cool??? Link to comment Share on other sites More sharing options...
northguy Posted December 10, 2003 Share Posted December 10, 2003 I put high output headlights in my 83 Brat and it made a big difference. The new blue lights are supposed to be even better. It was about $14 per headlight. Just installed low beams. Fixed the problem for under $30. Link to comment Share on other sites More sharing options...
ru4x4ever Posted December 10, 2003 Author Share Posted December 10, 2003 I have those crappy sealed headlights is that what you mean the whole thing, or did you just have a replacable bulb? Link to comment Share on other sites More sharing options...
Snowman Posted December 10, 2003 Share Posted December 10, 2003 I just said "screw it" and bought a pair of 55 watt driving lights that I turn on any time it's dark. Link to comment Share on other sites More sharing options...
torxxx Posted December 10, 2003 Share Posted December 10, 2003 yup driving lights or fog lights.. Get ones that are blue/white in color they look brighter. Link to comment Share on other sites More sharing options...
Rooinater Posted December 10, 2003 Share Posted December 10, 2003 driving lights are probably the best bet. i helped brighten mine by cleaning all the contacts in the fuse pnl, on the lights and the gnd wires. it helped but they still suck. the other option is to reroute wires and use a relay straight off the batt. that'd help a lot. hook the relay up so it operates with the old switch and uses pure batt pwr to the lights. other than that just use driving lights. relays aren't too expensive, and you only need a small amount of electrical knowledge to create the circuit, or use a diagram. those are the easiest way to create the circuit. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 10, 2003 Share Posted December 10, 2003 Blue light is NOT better for visibility, and White is also not optimal. The Sun is more yellow, and your eyes were designed to see in that light. Study's have been done to this effect..... the blue and purple lights just look cool, nothing more. GD Link to comment Share on other sites More sharing options...
mdjdc Posted December 10, 2003 Share Posted December 10, 2003 Look in the JC whitney catalog. they have high output lights at bargain prices and they will just pop right into your frames. Link to comment Share on other sites More sharing options...
dneet Posted December 11, 2003 Share Posted December 11, 2003 I just put on a set of Hella lights (four lights)on my 84 wagon $$$$$$. Low beam is 55/65, works great. Tried putting in 100 watt on the high beam. It looks like the wiring and or relay dosn't like the large draw on high beam. I'm going to rewire the high beam with a new power supply and relay. If you want to go nuts, try to figure out the wiring circuit. Still looking for the ground circuit. banghead: P.S. After I bought the lights I was told that the larger single lights put out more light that the four light system. :boohoo: Link to comment Share on other sites More sharing options...
torxxx Posted December 12, 2003 Share Posted December 12, 2003 Lol.. GD come up to Fairbanks where its dark for 18 hours a day and tell me my blue/white fog lights are as "seeable" as the yellow ones.. They shine 3 times farther then my yellow headlights with more illumination. How often do you stare directly at the sun when your driving? There's more blue/white light in the atmosphere for most of the day then there is "yellow" sun light.. How could peoples eyes be more used to seeing that? Quote Originally posted by GeneralDisorder Blue light is NOT better for visibility, and White is also not optimal. The Sun is more yellow, and your eyes were designed to see in that light. Study's have been done to this effect..... the blue and purple lights just look cool, nothing more. GD Link to comment Share on other sites More sharing options...
