popeye2 Posted October 11, 2007 Share Posted October 11, 2007 I have a 2001 Subaru OBW. I'm trying to use a Harrison R&D scanner on it and I'm getting no response from the vehicle. It works on my 2003 Ford work van, and my son's 2001 Jeep Cherokee, but not the Subaru. Any ideas? Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted October 12, 2007 Share Posted October 12, 2007 Hi. Not sure what to say. You have the key in 'run' right? It will not read otherwise in my experience, on a soob anyway. I've used a couple ODBII code readers on soobs and they work with key in 'run' (not 'acc') and even engine running if desired. Quote Link to comment Share on other sites More sharing options...
popeye2 Posted October 12, 2007 Author Share Posted October 12, 2007 As a reminder this is on a 2001 OBW, but I did remember that when I previously scanned the car , way back when, I had connected a pair of green wire connectors(called test mode connectors) under the dash, drivers side, next to the console as suggestsed in factory service manual. When I connected the pair this time it didn't do anything with allowing the scan, but it did set off the check engine light flashing, the engine cooling fan cycling on /off and who knows what else. Anyone out there had problems scanning their Subaru? Quote Link to comment Share on other sites More sharing options...
srs_49 Posted October 12, 2007 Share Posted October 12, 2007 I use an Accutron (not sure of the model) on our 2002 OBW without any problems. The key does have to be turned to the "run" position, as someone else pointed out. The Accutron reads and resets the codes fine. No need for any jumpers. Quote Link to comment Share on other sites More sharing options...
OB99W Posted October 12, 2007 Share Posted October 12, 2007 You shouldn't have to couple the green test mode connectors to do an OBDII scan. Assuming the Harrison scanner incorporates the proper communication protocol, I'd check for a possibly blown fuse in the Subaru. Quote Link to comment Share on other sites More sharing options...
popeye2 Posted October 12, 2007 Author Share Posted October 12, 2007 I heard mention of the cigar lighter fuse being tied into the test port, is this the case? What does the green test mode connector do? Do any of the symptoms I mentioned when the test connetor was connected make any sense? The scanner was ISO 9141 protocol, but had it updated to the KWP 2000 a while back , should that matter? You shouldn't have to couple the green test mode connectors to do an OBDII scan. Assuming the Harrison scanner incorporates the proper communication protocol, I'd check for a possibly blown fuse in the Subaru. Quote Link to comment Share on other sites More sharing options...
2X2KOB Posted October 12, 2007 Share Posted October 12, 2007 Your scanner just might be incompatible with this car for some reason. Can you go to someplace like an Autozone where they read codes for free, and see if their scanner works on your car? Quote Link to comment Share on other sites More sharing options...
popeye2 Posted October 12, 2007 Author Share Posted October 12, 2007 I''try Auto Zone , but it work at one time, so I don't know if the protocol update makes a difference or not. OB99W, any idea what fuse it might be? Quote Link to comment Share on other sites More sharing options...
OB99W Posted October 12, 2007 Share Posted October 12, 2007 [...]Do any of the symptoms I mentioned when the test connetor was connected make any sense?Yes, that's typical behavior with the test mode connectors attached. Leave them disconnected. The scanner was ISO 9141 protocol, but had it updated to the KWP 2000 a while back , should that matter? I''try Auto Zone , but it work at one time, so I don't know if the protocol update makes a difference or not.If the scanner was ISO-9141 compatible and working properly, adding KWP2000 compatibility shouldn't have changed things; if it did, I'd suggest asking Harrison R&D what's going on. OB99W, any idea what fuse it might be?Not offhand, but the DLC (Diagnostic Link Connector) definitely is fused, usually along with other things on the same circuit. Quote Link to comment Share on other sites More sharing options...
popeye2 Posted October 13, 2007 Author Share Posted October 13, 2007 I thank you both for your help, I will check for a blown fuse. Dan Harrison of Harrison R&D has assurred me that the addition of the new protocol would not effect it. I'll post to this message when I check the fuse, and if it is OK I'll return the scanner for a check up as he suggested. I have no idea how these scanners work but he figures the ISO 9141 protocol isn't functioning and the KWP 2000 is, hence the ability to scan my 2003 Ford work van, but not the 2001 Subaru. Does that make sense? Quote Link to comment Share on other sites More sharing options...
bulwnkl Posted October 13, 2007 Share Posted October 13, 2007 We recently acquired an OBD II scanner/logger and it would not work on my '05 Baja. Updated the firmware through the included utility and now it works fine. That was an Innova, IIRC. Quote Link to comment Share on other sites More sharing options...
OB99W Posted October 13, 2007 Share Posted October 13, 2007 [...]he figures the ISO 9141 protocol isn't functioning and the KWP 2000 is, hence the ability to scan my 2003 Ford work van, but not the 2001 Subaru. Does that make sense?Yes, it's possible for only the ISO-9141 operation to be faulty. You may have checked for this already, but make sure that none of the pins are bent and that the connector is being fully inserted; sometimes they're a bit tight and don't make good contact without a little "convincing". If you can easily get to the back of the DLC in the car, make sure all of it's pins are latched into the connector body. Otherwise, if it's not something simple like a blown fuse or connector trouble on the Subaru, then it could be a problem with the ECU (but I wouldn't jump to that conclusion yet). Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted October 14, 2007 Share Posted October 14, 2007 when you take the scanner in for it's check up, take the subaru as well. he should be able to scan your car and that will tell you if is the car or the tool. Quote Link to comment Share on other sites More sharing options...
popeye2 Posted October 15, 2007 Author Share Posted October 15, 2007 All the fuses under the dash and the hood proved to be fine, in addition I had a test scan done at a local Advance Auto, their scanner worked fine. The scanner is in the mail back to the builder this AM. Quote Link to comment Share on other sites More sharing options...
popeye2 Posted October 31, 2007 Author Share Posted October 31, 2007 I thought I'd update you on this, I returned the scanner for repair and it was at fault, its is now repaired and works fine, without any extra connecting under the dash as previously mentioned. Quote Link to comment Share on other sites More sharing options...
