Are the fans from a 96 outback thermostatically controlled at the motor, have a thermostat elsewhere in the engine bay, or are they switched on and off directly by the ecu? The reason I ask is I am looking to modify a pair of spare fans to another vehicle and want to maintain some sort of automatic control, in conjunction with a dash switch. Thanks alot for the help.
From what you stated in your first post it seems to me that all you need to do is add a bypass circuit to the fans. This would just take a fuse, relay, and switch to turn on the fans manually. I may not fully understand what you are trying to do though.
I'm trying to install these fans in my 86 mercury cougar. I want the clutch fan gone to make more room, and free up some 15 horses. I did intend to run a manual switch, but wanted them to have an automatic mode. They sell thermostatic fan control kits like this at the autoparts store but they cost like $80. I was looking to keep this project from costing me anything, other than the spare parts I already have kicking around. I have a wide variety of relays, switches, and other electronic doo-dads but no electronic thermostats. I guess its time to start cruising E-bay!
The only thing I think you will need then is the thermostat switch. Hopefully the radiator has a spot for installing one. Then just add your relay and power supply circuit to it. You don't have to have an electronic control to turn it on.
