milestoempty Posted October 14, 2007 Share Posted October 14, 2007 So I got a killer deal on an STI exhaust going on. Like $50 bucks for the whole thing. Downpipe, midpipe/resonator, muffler. Im just wondering what I would nee to do to make it fit. Will the muffler even fit? I know the WRX/STI mufflers are quite large. What will I need to modify? How should I go about making the downpipe fit the EA82t's turbo? Quote Link to comment Share on other sites More sharing options...
baccaruda Posted October 14, 2007 Share Posted October 14, 2007 the downpipe will fit if you change the flange.. and... I have a WRX downpipe in my EA81T. I had to change the flange over as well as elongate the top/front curve of the downpipe to meet the turbo. the WRX/STI turbos are larger so the front of the downpipe has to be brought forward a little bit. You also have the option of putting a WRX turbo on your EA82T but that opens up a whole other can of worms. I suggest that you maximize the intake and exhaust flow potential and leave the stock turbo on it, as you seem to be asking about doing anyway. If you want to commit to it, chop the flange off of the front of the STI downpipe and remove the stock one, see how it lines up. Put a brick or 2 under the car to hold it close to where it needs to go. It slightly reduced the ground clearance in my EA81T coupe but not badly. Speaking of all this, you *do* know the chop-out-the-bottom-of-the-air filter-box trick, right? Quote Link to comment Share on other sites More sharing options...
milestoempty Posted October 14, 2007 Author Share Posted October 14, 2007 the downpipe will fit if you change the flange.. and...I have a WRX downpipe in my EA81T. I had to change the flange over as well as elongate the top/front curve of the downpipe to meet the turbo. the WRX/STI turbos are larger so the front of the downpipe has to be brought forward a little bit. You also have the option of putting a WRX turbo on your EA82T but that opens up a whole other can of worms. I suggest that you maximize the intake and exhaust flow potential and leave the stock turbo on it, as you seem to be asking about doing anyway. If you want to commit to it, chop the flange off of the front of the STI downpipe and remove the stock one, see how it lines up. Put a brick or 2 under the car to hold it close to where it needs to go. It slightly reduced the ground clearance in my EA81T coupe but not badly. Speaking of all this, you *do* know the chop-out-the-bottom-of-the-air filter-box trick, right? Mmm no, please inform me Never should have mentioned that a TD04 would be a consideration... Ooooh boy. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted October 14, 2007 Share Posted October 14, 2007 Delta 260 cams, rebuilt gen 2 turbo heads, Megan Racing 3" bellmouth downpipe, TD04 turbo, WRX TMIC with Turbo XS BOV, '88 XT spyder intake, Nissan 280ZX turbo injectors, SPFI shortblock, Samco intercooler hoses, AEM cold air intake, plus 3 blown engines. Unless you plan on getting a good fuel management setup or feel like investing in engines, not much of a worthwhile investment to do serious power upgrades to the EA82T. You can do some (like intake, exhaust, intercooler) but I went through 3 engines and said that I was done. Quote Link to comment Share on other sites More sharing options...
milestoempty Posted October 15, 2007 Author Share Posted October 15, 2007 maybe Ill just port the mouth of the stock downpipe and put he sti exhaust on cat back style. Quote Link to comment Share on other sites More sharing options...
kingbobdole Posted October 15, 2007 Share Posted October 15, 2007 Won't fit... I had one for my RX.... the muffler... well takes up the room between the bumper and the axle.... and then the input is right where the axle is... it, just doesn't work. Quote Link to comment Share on other sites More sharing options...
Zefy Posted October 16, 2007 Share Posted October 16, 2007 hack off the tip, weld it on... there... sti exhaust...:-p the tip is the cool part anyways... then sell the stock dp and everything on nasioc for oodles of money... Quote Link to comment Share on other sites More sharing options...
milestoempty Posted October 18, 2007 Author Share Posted October 18, 2007 Ok then scrap that idea.... What should I do for an exhaust upgrade then? Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted October 18, 2007 Share Posted October 18, 2007 Ok then scrap that idea.... What should I do for an exhaust upgrade then? gut the cats and put a custom axleback on it. Quote Link to comment Share on other sites More sharing options...
