PeterD Posted October 15, 2007 Share Posted October 15, 2007 after succesfuly installing the tranny after replacing the clutch last night i had this itch that i did something wrong so today i had my dad help me pull the tranny back out:mad: i was upset it was a pain in the rear getting it all back together. any way i found that the retaining clips for the release(throwout ) bearing were not were they should be and i should replace them. NOw im upset becuase the parts dept is usualy closed on sunday so i have to figure out a car to drive to work in the morning:-\ so thats worked out now i have a car, but now i hope i can get the proper clips from the dealer. i now will be installing the tranny at night after work possibly tomarow in the dark and hopfully the weather stays nice. My next issue is the throw out bearing alignment. please look at the picture and tell me what way this bearing should be installed, its brand new and looks just like the one that came off the car. notice the gap on the top and bottom of that plastic bushing that the bearing slides back and forth on. shoud that be on the top our bottom when i install the bearing. there has to be a reason for this.. Link to comment Share on other sites More sharing options...
lmdew Posted October 15, 2007 Share Posted October 15, 2007 It should center, if not there is something wrong with the bearing. Link to comment Share on other sites More sharing options...
OB99W Posted October 15, 2007 Share Posted October 15, 2007 [...]My next issue is the throw out bearing alignment. please look at the picture and tell me what way this bearing should be installed, its brand new and looks just like the one that came off the car. notice the gap on the top and bottom of that plastic bushing that the bearing slides back and forth on. shoud that be on the top our bottom when i install the bearing. there has to be a reason for this.. Many throwout bearings are self-aligning/self-centering; even if they appear to be "off" before installation, they align correctly when in use. Link to comment Share on other sites More sharing options...
PeterD Posted October 15, 2007 Author Share Posted October 15, 2007 it just seems kindof strange, and no most bearings newones that i have looked at are all the same. they look off center Link to comment Share on other sites More sharing options...
uniberp Posted October 15, 2007 Share Posted October 15, 2007 it just seems kindof strange, and no most bearings newones that i have looked at are all the same. they look off center Dues can only be paid in the rain and cold. A drivetrain or engine bearing will not have a stamped shell. That stamped outervshell probably floats around the machined bearing even if tightly fitting. You're young. Applicance carton cardboard is your friend for working under a car. Please use jackstands on a level surface. Link to comment Share on other sites More sharing options...
PeterD Posted October 15, 2007 Author Share Posted October 15, 2007 a Dues can only be paid in the rain and cold. A drivetrain or engine bearing will not have a stamped shell. That stamped outervshell probably floats around the machined bearing even if tightly fitting. You're young. Applicance carton cardboard is your friend for working under a car. Please use jackstands on a level surface. I may be young but this is my 4th clutch since highschool. but ive never done a new gen subaru or even pulled the tranny out most of the subarus i pulled the engine. .. i chose this beautifull weekend for its wonderfull weather but the PNW fights back and shows whos boss. :-\ its raining today hopfully it will let up a bit this afternoon. I have some of the most specacular cardboard also.. double layer i beleve. i now have all the parts and hopfully it will be back up tonight while working under lights. Link to comment Share on other sites More sharing options...
PeterD Posted October 16, 2007 Author Share Posted October 16, 2007 it works!!! its a self aligning bearing and the new retaining clips im gad i waited for. thanks for the wee bit of help. Link to comment Share on other sites More sharing options...
OB99W Posted October 17, 2007 Share Posted October 17, 2007 [...]its a self aligning bearing[...]thanks for the wee bit of help.You're welcome, a wee bit. Link to comment Share on other sites More sharing options...
PeterD Posted October 17, 2007 Author Share Posted October 17, 2007 You're welcome, a wee bit. well my Dad also asked a Subaru tech the other day for me. you were right i just needed confermation :cool: Link to comment Share on other sites More sharing options...
