LosDiosDeVerde86 Posted October 15, 2007 Share Posted October 15, 2007 OK, I'm not going to get into the long story about this car, but here's the specs: 1999 Legacy GT Limited Sedan Automatic 34,000 miles Symptoms: 1 Weak start 1 (followed by 2 immediate) No Starts (starter cranked twice and stopped) Lights didn't APPEAR to be dimmer, but I could be wrong Garage says battery gives proper volts Starts immediately with jump Could be: Camshaft Sensors (trust me...had that happen with my '96) Battery ??? What else? (this is where YOU come in.) Link to comment Share on other sites More sharing options...
porcupine73 Posted October 16, 2007 Share Posted October 16, 2007 Battery should be load tested; like 100 amps load for 10 seconds then read voltage. Make sure your battery cables and connections are clean in good shape and tight. Check the ground connection to the starter also. When you say it starts right away if jumped, is the jumper cable ground cable at your vehicle connected to the battery terminal, or somewhere else? Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted October 16, 2007 Author Share Posted October 16, 2007 Battery should be load tested; like 100 amps load for 10 seconds then read voltage. Make sure your battery cables and connections are clean in good shape and tight. Check the ground connection to the starter also. When you say it starts right away if jumped, is the jumper cable ground cable at your vehicle connected to the battery terminal, or somewhere else? battery terminal Link to comment Share on other sites More sharing options...
porcupine73 Posted October 16, 2007 Share Posted October 16, 2007 battery terminalDefinitely battery should be load tested (a simple voltage test is not sufficient), and pull both battery terminals, clean them and the battery posts, reconnect snuggly. Ideally leave the battery disconnected for an hour or so to avoid potential memory corruption issues that some years had in the ECU. Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted October 16, 2007 Author Share Posted October 16, 2007 think there's any possibility of it being the starter? Link to comment Share on other sites More sharing options...
porcupine73 Posted October 16, 2007 Share Posted October 16, 2007 Possibly starter I suppose; though that would not explain why it starts when it is jumped. Typically when soob starter contacts, etc go, they won't crank at all, or you have to bump the key several times to get it to crank. Cranking a little and then stopping sounds different. Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted October 16, 2007 Author Share Posted October 16, 2007 Possibly starter I suppose; though that would not explain why it starts when it is jumped. Typically when soob starter contacts, etc go, they won't crank at all, or you have to bump the key several times to get it to crank. Cranking a little and then stopping sounds different. i see. i'm just trying to come up with anything i can to make this car as good as it can be Link to comment Share on other sites More sharing options...
nipper Posted October 16, 2007 Share Posted October 16, 2007 Starter contacts, maybe Cam sensor - controls fuel injection Crank sensor - controls spark a slow crank, look at the battery terminals, the cables, the grounds. Low mileage cars are not always good things. For every month of age is the same as 1000 miles of wear and tear. nipper Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted October 16, 2007 Author Share Posted October 16, 2007 Low mileage cars are not always good things. For every month of age is the same as 1000 miles of wear and tear. nipper *singing* "Here comes Nipper Downer!" Link to comment Share on other sites More sharing options...
Virrdog Posted October 16, 2007 Share Posted October 16, 2007 I would almost definitely pin that on the battery or battery connection. Clean up all the contacts like the other people mention. I had this happen in my '89 wagon a couple of weeks ago. The negative battery terminal was just not square on the post apparently. Caused a no-start with weird conditions. If the connection is not the problem, go ahead and buy another one. That way you have the funky one as an emergency backup. Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted October 16, 2007 Author Share Posted October 16, 2007 I would almost definitely pin that on the battery or battery connection. Clean up all the contacts like the other people mention. I had this happen in my '89 wagon a couple of weeks ago. The negative battery terminal was just not square on the post apparently. Caused a no-start with weird conditions. If the connection is not the problem, go ahead and buy another one. That way you have the funky one as an emergency backup. keep in mind that the car's at a dealership in pittsburgh and i'm in columbus. i would sure HOPE that they would think to check the connections. the mechanic took the car home tonight so hoopefully he's able to recreate some of the problems. Link to comment Share on other sites More sharing options...
