paulpicard Posted October 16, 2007 Share Posted October 16, 2007 Couldn't find what I wanted by searching, so I'll ask - why I only see Peugeot wheels as a straight swap to Soobs. I am looking for another set of wheels with snows mounted, and come across lots of 4x100 stuff for other Japanese cars. Doesn't my Loyale have 4x100mm bolt pattern? Any reason I can't use Honda/Toyota 13 or 14" 4x100's? Link to comment Share on other sites More sharing options...
82glsw Posted October 16, 2007 Share Posted October 16, 2007 Couldn't find what I wanted by searching, so I'll ask - why I only see Peugeot wheels as a straight swap to Soobs. I am looking for another set of wheels with snows mounted, and come across lots of 4x100 stuff for other Japanese cars. Doesn't my Loyale have 4x100mm bolt pattern? Any reason I can't use Honda/Toyota 13 or 14" 4x100's? Loyale has a 4x140 bolt pattern Link to comment Share on other sites More sharing options...
Quidam Posted October 16, 2007 Share Posted October 16, 2007 Loyale has a 4x140 bolt pattern Wheels for the EA-82. Pain in the rump roast in our neck of the woods. Good wheels, that is. I've spent more time refinishing these things.... A good wheel, 4X140, here, is worth $50.00 to me. That's just wrong, for stock. sigh, oh well. Later Link to comment Share on other sites More sharing options...
paulpicard Posted October 16, 2007 Author Share Posted October 16, 2007 Well, I don't know where I got the 4x100mm from, but 4x140mm explains everything. Thanks, people:mad: Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 16, 2007 Share Posted October 16, 2007 Just drill your hubs for 6 lug Chevy. It's not like it's difficult - you need 8 studs from either the JY or the parts store, a center punch and a drill. 6x5.5" rims are everywhere - Toyota, Mazda, GM.... there's TONS of them. Stock 15" Toyota truck rims have the correct offset, as do many Mazda truck rims. GD Link to comment Share on other sites More sharing options...
paulpicard Posted October 16, 2007 Author Share Posted October 16, 2007 Thanks, gd. But can you give me some more details, or a link to a template? Use any of the stock holes? (I'm visualising the 12 and 6 o'clock stock holes with 4 new ones but that sounds too simple!!) Link to comment Share on other sites More sharing options...
WoodsWagon Posted October 16, 2007 Share Posted October 16, 2007 (I'm visualising the 12 and 6 o'clock stock holes with 4 new ones but that sounds too simple!!) That's exactly how six lug is done. Now, you have two options, drill holes in the wheels or drill holes in the hub and put studs in. I chose to drill holes in my wheels, so I have 4 unused holes in the center of the rim. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 16, 2007 Share Posted October 16, 2007 Thanks, gd. But can you give me some more details, or a link to a template? Use any of the stock holes? (I'm visualising the 12 and 6 o'clock stock holes with 4 new ones but that sounds too simple!!) Yep - you got the idea. You use the 6 lug rim as a template. Knock out two studs on the hub/drum, and bolt it to the rim. Then mark the hub/drum through the other 4 holes in the rim. Simple. Center punch, drill, pound in 4 studs. Done. Some grinding on the backside where the stud seats might be needed too, but people have used either longer studs, or not bothered and it doesn't seem to matter a whole lot. Drilling holes in the wheels to make them 4 lug is fine too, but obviously doesn't work for alloys. I have done both, and both work well even for large tires - although if you get into the 30"+ tire range (transfer case lift, etc) then I would go with the 6 lug as there are cases where people have sheered off 4 lug rims with really huge tires. GD Link to comment Share on other sites More sharing options...
testy Posted October 16, 2007 Share Posted October 16, 2007 Theres an old guy in burnaby who works on peugeots and hes got a tons of wheels laying around. I got my 14" Steel pugs (peugeot 505) wheels for $25 each with lugs nuts. Hes the same price for 15" Steels. He does Alloys for $40-45 each with the lug nuts aswell. I beleive Alphi's euro junkyard /wheelshop in Surrey on Scott Rd. has a set of 15 inch Pug Alloys, they had em a year ago when I was looking. Not sure the price but they looked nice. Here is a great tutorial on a 6 lug swap: http://www.subarubrat.com/6lugconv.htm Link to comment Share on other sites More sharing options...
paulpicard Posted October 16, 2007 Author Share Posted October 16, 2007 Testy, do you have any more details for the "old guy in Burnaby"? How to get ahold of him? Peugeot wheels are obviously the easy way out but I doubt any Peugeots have ever been seen in my neighborhood let alone in the local j/y. He had a Soob once for a year or 2 but nobody needed parts so he crushed it. GD, thanks for the added info. I do have a decent drill press so drilling the hubs isn't too scary. I assume one would use GM spec studs, or is there any appreciable difference from the Soob stud? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 16, 2007 Share Posted October 16, 2007 I assume one would use GM spec studs, or is there any appreciable difference from the Soob stud? The Subaru studs seem to work fine for me and everyone I know that's done it. They don't pull through the rim or anything if that's what you mean. Very solid and mine take quite a bit of puhishment. On my lifted wagon I drilled brand new Chevy white spoke wagon rims ($27 each - brand new) over to 4 lug. It's nice having the new powder coated rims - easy to wash the mud off. GD Link to comment Share on other sites More sharing options...
testy Posted October 16, 2007 Share Posted October 16, 2007 Testy, do you have any more details for the "old guy in Burnaby"? How to get ahold of him? Peugeot wheels are obviously the easy way out but I doubt any Peugeots have ever been seen in my neighborhood let alone in the local j/y. He had a Soob once for a year or 2 but nobody needed parts so he crushed it. GD, thanks for the added info. I do have a decent drill press so drilling the hubs isn't too scary. I assume one would use GM spec studs, or is there any appreciable difference from the Soob stud? Check the thread I made. Should still be on the first page. "The finding pugs in bc thread" or something like that. Link to comment Share on other sites More sharing options...
paulpicard Posted October 17, 2007 Author Share Posted October 17, 2007 Terrific response, people. This board is a great resource, and I thank all of you for your help. Link to comment Share on other sites More sharing options...
beataru Posted October 17, 2007 Share Posted October 17, 2007 Wheels for the EA-82. Pain in the rump roast in our neck of the woods. Good wheels, that is. I've spent more time refinishing these things.... A good wheel, 4X140, here, is worth $50.00 to me. That's just wrong, for stock. sigh, oh well. Later Mine has VHT flat black on them, I have to touch these things up so much, I am seriously considering powedercoating them to semigloss black (thats only if blueroo at least tries to give me stock hp back thats all I ask) Link to comment Share on other sites More sharing options...
