thealleyboy Posted October 16, 2007 Share Posted October 16, 2007 Did an A/T to D/R conversion on an 88 GL Wagon, and it does not appear that the clutch is engaging properly (acts as in Neutral all the time). All new parts including clips, cable and both bearings. Everything looked good before mating the tranny to the motor, and there were no major issues during installation. Shift linkages/rods are all lubed up and moving as they should. Tried playing around with cable adjustments, and while the pedal "feels" right, nothing happens when shifting into gear. Fork appears to positioned properly. note: I'm working alone, so I cannot see all the mechanisms in action at once. Also, the car has not moved since the swap, and I dont know if rolling it out in neutral would help engage the clutch somehow. Any thoughts on what might be going on here? I'd like to pinpoint the problem before dropping the tranny all over again:mad: ... thanks, John Link to comment Share on other sites More sharing options...
TomRhere Posted October 17, 2007 Share Posted October 17, 2007 I recall reading a simular thread awhile back. Seems it was something to do with the Range selector/linkage. Got knocked into a "between gears position" during install, lever "looked" right. IIRC.... Link to comment Share on other sites More sharing options...
daeron Posted October 17, 2007 Share Posted October 17, 2007 I recall reading a simular thread awhile back. Seems it was something to do with the Range selector/linkage. Got knocked into a "between gears position" during install, lever "looked" right. IIRC.... I think i remember something about that thread too. I was going to say something, but sometimes (believe it or not) I opt to NOT post, and leave it to someone else Link to comment Share on other sites More sharing options...
mikeshoup Posted October 17, 2007 Share Posted October 17, 2007 Yeah, there's a neutral spot in the dual range between 4HI and 4LO. Check that you're not in that spot. Link to comment Share on other sites More sharing options...
thealleyboy Posted October 17, 2007 Author Share Posted October 17, 2007 Yeah, the hi/lo system would make sense... What I don't understand is how it could have got stuck in "N" during installation. And why wouldn't it shake out while shifting around the gearbox. I mean, you'd think that this would be a fool-proof operation as far as the rods and linkages. So, would the fix be to simply remove/reinstall the shifting hardware? Or, drop the tranny, and make sure it is mated up "in gear", when re-installing? John Link to comment Share on other sites More sharing options...
nvexplorer Posted October 17, 2007 Share Posted October 17, 2007 If its in the D/R neutral position you should be able to pull up or push down on the 4wd stick to engage 4wd and that would tell you if you are inbetween 4hi and 4low. Your car should also move when in 4wd. Hopefully thats all it is and the linkage just needs to be adjusted or pushed all the way down. Good luck! Link to comment Share on other sites More sharing options...
nipper Posted October 17, 2007 Share Posted October 17, 2007 Hehehe this is the old gen version of the virgin switch. The 4wd is in the neutral position, so technically, yes, it is always in neutral. Push the lever down (2wd) or up (4wd) just to make sure the driveline works. nipper Link to comment Share on other sites More sharing options...
mikeshoup Posted October 17, 2007 Share Posted October 17, 2007 Another possibility, but remote, is one of your axles badly damaged to the point a CV is gone? Try shifting between 4WD and 2WD. Link to comment Share on other sites More sharing options...
nipper Posted October 17, 2007 Share Posted October 17, 2007 Another possibility, but remote, is one of your axles badly damaged to the point a CV is gone? Try shifting between 4WD and 2WD. 10 pts for that one nipper Link to comment Share on other sites More sharing options...
MilesFox Posted October 19, 2007 Share Posted October 19, 2007 hey i broke an axle once and had to park my car on an enbankment and after hitch hiking to a junkyard and returning the with another axle i put it on and my vcar would not go. i already hjad taken one bellhousing bolt out before i thought to check the 4wd linkage, which actually was bumped into "false neutral" when the car ran up over the curb of the embankment the other 2 times i had seen a clutch not engage was once on a 81 glf that sat in a farmers field for better than 10 years and the other instance a clutch was smoked so bad the dust made the disc stick in the flywheel. Link to comment Share on other sites More sharing options...
s'ko Posted October 19, 2007 Share Posted October 19, 2007 I had a cv joint slip of the axle shaft. It just spun around and the BRAT didn't go anywhere b/c of the open diff. Look into the d/r shifters first and then look at the axle. A lot easier than ripping things apart. Link to comment Share on other sites More sharing options...
thealleyboy Posted October 21, 2007 Author Share Posted October 21, 2007 I finally had a chance to mess with it again last nite... Apparently, it was a combination of things. Something was binding somewhere. It took rolling the car back and forth in "N", and some hard shifting, but it finally engaged. Thanks for all the comments guys!! I was frustrated to the point to were I was about ready to tear it all down again. John Link to comment Share on other sites More sharing options...
