3Pin Posted October 17, 2007 Share Posted October 17, 2007 Have a bad engine in a 2000 forester with a manual. What is the best 2.2 engine swap for this? I did put a 95 2.2 into my 98 Forester, but that was an automatic. Thanks for the help in advance. Link to comment Share on other sites More sharing options...
Towel Rail Posted October 17, 2007 Share Posted October 17, 2007 EJ22T. Link to comment Share on other sites More sharing options...
3Pin Posted October 17, 2007 Author Share Posted October 17, 2007 After searching the swaps, it looks like a 99 2.2l is the easiest best swap for a 2000 Forester with a manual. Something about the 99 2.2 being a phase II by then, but not much more info than that. Does anyone else have an opinion? How much more work is it on a 95 or 96 2.2 manual? Link to comment Share on other sites More sharing options...
idosubaru Posted October 17, 2007 Share Posted October 17, 2007 get the 99 2.2 and get the exhaust header as well. what you'll really want to make sure of is that the EGR systems are identical, it will either have it or not have it. if the 99 in the forester has EGR, you'll want to make sure the 2.2 has it as well. did you pick that forester up from a dealer? i was looking at one up that way, they never called back. maybe it's because you got it! Link to comment Share on other sites More sharing options...
3Pin Posted October 17, 2007 Author Share Posted October 17, 2007 This car has a stick. Will it have an EGR? Link to comment Share on other sites More sharing options...
idosubaru Posted October 17, 2007 Share Posted October 17, 2007 This car has a stick. Will it have an EGR? not sure, i want to say it will, but i can't recall when the quit putting the EGR on. i think they quit at some point. is this car from a dealer? that would be funny if it was the same one i was looking at. Link to comment Share on other sites More sharing options...
3Pin Posted October 17, 2007 Author Share Posted October 17, 2007 No, this one is private party. Link to comment Share on other sites More sharing options...
idosubaru Posted October 17, 2007 Share Posted October 17, 2007 No, this one is private party.hmmm, it was a long shot but would have been cool for you to get it versus someone else. so long as you retain your intake manifold i don't think you'll have a problem installing another year EJ25. i don't think the EJ22 and EJ25 intakes swap so you can't do it that simply. Link to comment Share on other sites More sharing options...
WAWalker Posted October 17, 2007 Share Posted October 17, 2007 Your Phase II 2.5L intake should fit on a Phase II 2.2L from a Legacy. I don't see why that wouldn't work. But I do not remember if the Phase II 2.2L's have EGR. I believe they do. A '95-'96 2.2L is out of the question for what you want to do. Won't work. Link to comment Share on other sites More sharing options...
3Pin Posted October 17, 2007 Author Share Posted October 17, 2007 Thanks for the info on the 95-96 not working out. It saves me a stupid move. Looks like the 99 2.2 or a different 2.5 will have to do. Link to comment Share on other sites More sharing options...
cookie Posted October 17, 2007 Share Posted October 17, 2007 I was trying to figure that out myself. I have a 99 Forester that I'm planning on eventually using a 2.2 in. I'll have to check to see if it has EGR. The extra bolts would seem to me to make it necessary to use a 99 up 2.2. Link to comment Share on other sites More sharing options...
soobiedo Posted October 28, 2009 Share Posted October 28, 2009 Does anyone know if a 2001 2.2L from an Impreza will swap into a 2000 Forester, MT? My biggest concern is plugging in the wiring harness. I know I'll have to swap y-pipe, tap the starter hole, etc. Link to comment Share on other sites More sharing options...
wtdash Posted October 28, 2009 Share Posted October 28, 2009 Does anyone know if a 2001 2.2L from an Impreza will swap into a 2000 Forester, MT? My biggest concern is plugging in the wiring harness. I know I'll have to swap y-pipe, tap the starter hole, etc. Hi, FYI - best to start a New Thread, rather than hi-jack this old one ('07). I'd check over on 'nasioc.com' and 'subaruforester.org'. GL, TD Link to comment Share on other sites More sharing options...
idosubaru Posted October 28, 2009 Share Posted October 28, 2009 Does anyone know if a 2001 2.2L from an Impreza will swap into a 2000 Forester, MT? My biggest concern is plugging in the wiring harness. I know I'll have to swap y-pipe, tap the starter hole, etc. yes, but you'll likely need to swap cam sprockets between the two. wiring harness won't matter since the forester manifold bolts up to the impreza engine so you'll be using the same harness (not true of all EJ swaps, but this one). Link to comment Share on other sites More sharing options...
subaru360 Posted October 28, 2009 Share Posted October 28, 2009 99 2.2 phase 2 into a 2000 forester should work fine. I did a 99 2.2 into a 99 forester and it came out well. I swapped the intake over, I think the crank or cam sprocket too, don't remember which, check both and you need a single port y pipe. Link to comment Share on other sites More sharing options...
