Yup, the original front rotors on the 2000 models were the same as the previous generation, and with the added weight didn't hold up as well.
I know that 2001 outbacks got the bigger front rotors, but I'm not sure if all the other models got them as well.
As far as I know, if you have the 16" wheels then you shouldn't have a problem putting on the bigger rotors.
There may be some more info in this thread as far as brakes go: http://usmb.ultimatesubaru.org/forum/showthread.php?s=&threadid=8060
There are a few recalls for rustproofing, and one or two other things, not sure which models it's for though. You might take a look here: http://www.nhtsa.dot.gov/ You can punch in the make model and get TSB and recall info.
Our '00 Legacy currently has 145,000 miles on it. We bought it 1/24/01 with 100,000 miles on it. We've had no trouble and are still running on the brakes pads that came on it. No warped rotors, no vibration, never seen the ABS light except when we turn on the ignition.
If you aren't a red light charger, you should have no trouble, if you do upgrade 'em.
