s'ko Posted October 17, 2007 Share Posted October 17, 2007 I have the RX minus engine w/complete exhaust system. Will the EA82T radiator be enough to keep things cool? also is there a turbo gauge or boost sensor on the EJ22T ECU? I wasn't able to find one on the diagram that I have. I will keep your all posted about the progress. BW Link to comment Share on other sites More sharing options...
subyrally Posted October 17, 2007 Share Posted October 17, 2007 i like this idea. as far as the radiator, i think that you can get one for the 89 turbo wagon with an auto tranny that is a three core deal. if i remember correctly, it wasnt that expinsive either. icant remember where i found that listed though. Link to comment Share on other sites More sharing options...
ThreeEyedBandit Posted October 18, 2007 Share Posted October 18, 2007 Quote I have the RX minus engine w/complete exhaust system. Will the EA82T radiator be enough to keep things cool? also is there a turbo gauge or boost sensor on the EJ22T ECU? I wasn't able to find one on the diagram that I have. I will keep your all posted about the progress. BW I dont know about the EA-82T radiator, is it a two core? The engine pressure sensor for the EJ-22T is on the passanger strut tower along with the Pressure exchange solenoid and wastegate control solenoid. All on a neat little bracket. Matt Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 18, 2007 Share Posted October 18, 2007 My ECU Scanner reports back intake manifold pressure, so i think there is some sort of boost sensor. -Brian Link to comment Share on other sites More sharing options...
MilesFox Posted October 19, 2007 Share Posted October 19, 2007 the hose diameter on the ej is larger than the ea82 radiator. an xt6 would be a better match since the hoses are larger than ea82, and if thy are the same size as the ej's. if you use a legacy radiator you would have to cut into the radiator support to let it sid down in about an inch and a half, otherwise it sits too high and you cant get it to fit inside its location i have mock installed an ej22 down into a gl-10 all but the wiring harness and the radiator i never got that far. this information is based on my attempt Link to comment Share on other sites More sharing options...
s'ko Posted October 22, 2007 Author Share Posted October 22, 2007 well. Spent a few hours stripping the harness and getting all of the ECU wires apart from the chassis harness. I am 80% done. Ran into a slight snag with the entire project that might force abandonment b/c the wife is not pleased w/having a 4th car. She said that if we do keep a 4th car it is going to be something that she likes. Unfortunately, she doesn't like soobies. She really wants to get a classic car, but that's mucho dinero there... will keep everyone posted with how that works out. BW Link to comment Share on other sites More sharing options...
subyrally Posted October 22, 2007 Share Posted October 22, 2007 good luck man, hope you can find a way to change her mind on that one. s said: well. Spent a few hours stripping the harness and getting all of the ECU wires apart from the chassis harness. I am 80% done. Ran into a slight snag with the entire project that might force abandonment b/c the wife is not pleased w/having a 4th car. She said that if we do keep a 4th car it is going to be something that she likes. Unfortunately' date=' she doesn't like soobies. She really wants to get a classic car, but that's mucho dinero there... will keep everyone posted with how that works out. BW[/quote'] Link to comment Share on other sites More sharing options...
Subarutex Posted October 22, 2007 Share Posted October 22, 2007 Use a brand new METAL EA82T dual row radiator. Have the inlets and outlets changed to ones that match a legacy. I believe it was 2-1/4" Diameter straight in, and straight out (no bends like the EA82's). It cost me $40 at a old time radiator repair place to have this done. This was for my EJ22 swapped GL Wagon. I rarely have to turn my fan on, usually only in traffic. I put a small 10" fan on the forward side of the radiator (mainly for cleaner engine bay appearance). My EJ20G swapped RX (UltimateRX) has a similar setup. The outlets however are not the correct size, and have a stepper hose attached. On this car there was fitted a dual 10" fan setup (with shroud and everything) forward of the radiator. This car gets driven more, and a lot harder, so I notice it runs the fans more. However, I'm using the Haltech (Standalone engine management) to turn the fan on and off at preset temps. I opted for fairly conservative temperatures. All in all, I see no reason why a good condition EA82 Dual Row radiator can't cool an EJ series engine. Link to comment Share on other sites More sharing options...
s'ko Posted October 25, 2007 Author Share Posted October 25, 2007 Haven't had a chance to work on it. One question I wanted to kick around. I have a WRX TMIC that I wanted to use but I don't really want to cut a hole in the hood for the scoop. Want it to be sleeper stock. So.... suggestions? Route air through hoses? I do plan to run a fan underneath the IC to help w/air flow. Maybe the combo the fan and ram air effect of ducts will get air going to the IC. Is that too much work for the end result? Link to comment Share on other sites More sharing options...
Numbchux Posted October 25, 2007 Share Posted October 25, 2007 Quote Haven't had a chance to work on it. One question I wanted to kick around. I have a WRX TMIC that I wanted to use but I don't really want to cut a hole in the hood for the scoop. Want it to be sleeper stock. So.... suggestions? Route air through hoses? I do plan to run a fan underneath the IC to help w/air flow. Maybe the combo the fan and ram air effect of ducts will get air going to the IC. Is that too much work for the end result? I've seen some goofy under-hood duct work to get air to an IC without having a scoop, and always heard bad things afterwards. you could see about getting a small FMIC to mount where the A/C condensor goes that might look stockish.... Link to comment Share on other sites More sharing options...
s'ko Posted October 25, 2007 Author Share Posted October 25, 2007 Numbchux said: I've seen some goofy under-hood duct work to get air to an IC without having a scoop, and always heard bad things afterwards. you could see about getting a small FMIC to mount where the A/C condensor goes that might look stockish.... I guess I could mount the TMIC as a FMIC. how does the routing go? Boosted air going into the IC and then into the throttle body. Once again probably too much work to get it to work. Might as well just cut a slit or mount a small low scoop. Link to comment Share on other sites More sharing options...
subyrally Posted October 25, 2007 Share Posted October 25, 2007 get a mistubishi starion intercooler, fits rather well behind the grill but youll have to rock out hood pins cause the hood latch will be in the way. Link to comment Share on other sites More sharing options...
yodannyc Posted October 26, 2007 Share Posted October 26, 2007 Hey S'Ko i am doing the same thing you are doing in to a 86' rx 4 door! let me know how your progress goes and i want to see pics! Link to comment Share on other sites More sharing options...
kingbobdole Posted October 31, 2007 Share Posted October 31, 2007 a few things... First I'm running an EJ25 in my Rx with the stock SINGLE core radiator. Not only that but I only have one fan, the stock A/C fan on the "wrong" side(left side) attached to a switch... I usually have it on... but then I don't pay much attention to the temp gauge and don't want to cook it. To "adapt" to the radiator, I just got "custom" searched-through-the-back-of-NAPA hoses with two different ends... one is a flexi hose. As far as your intercooler, you should buy mine! Flows better then the WRX and cools better, and no scoop! It's the AWIC off of a JDM Legacy. Here: http://www.ultimatesubaru.org/forum/showthread.php?t=78558&highlight=intercooler or here for more recent pics: http://www.awdpirates.net/phpBB2/viewtopic.php?t=27218 Link to comment Share on other sites More sharing options...
crazy D Posted November 2, 2007 Share Posted November 2, 2007 bosco,\ ill give you a call tonight cuz i want to here more about the projects. mostly to learn tho. i think you should do a mild hood scoop. would look really clean, but you'll see, that the way the Ea82 hoods are shaped that you might have to section out a piece of the scoop. ttyl -Dalton Link to comment Share on other sites More sharing options...
2K4 STI Posted November 12, 2007 Share Posted November 12, 2007 Any progress on your project? You can always do a scoop like this one.Looks like a sectioned down WRX scoop. http://www.cardomain.com/ride/2391065/4 Link to comment Share on other sites More sharing options...
s'ko Posted November 14, 2007 Author Share Posted November 14, 2007 2K4 STI said: Any progress on your project? You can always do a scoop like this one.Looks like a sectioned down WRX scoop. http://www.cardomain.com/ride/2391065/4 No new progress. I am just gathering parts. I think I am going with the AWIC route and make it super stealth. I like what the guy in the above site did for wheels by re-drilling for 4X100. There are sure a lot more choices there and usually sportier than the 6X140 truck wheels. I will probably have a shop or someone who a lot more precise than me do the re-drilling b/c there are no reference bolts to use like in the 6X140 mod. I doubt there will be real progress for a few months. Link to comment Share on other sites More sharing options...
s'ko Posted December 9, 2007 Author Share Posted December 9, 2007 Well I finally got some time yesterday to work on the swap. The EJ22T engine mounts were torn so I need to get a new set. Does the WRX ones fit? Also the adapter plate from Rguyver needs to be trimmed about an 1/2 or so in the passenger side in order to clear the turbo bracket. need to finish reaming two of the flywheel hole and then bolt it all up. I got the hook up on a cheap TDO4 so I will be looking into getting that put up. I already have a WRX downpipe so it the exhaust if going to be easy to complete. If you guys remember the FrankenBRAT, I just can't do a normal swap. I always have to add something different to the mix. This time I have been looking into alternative 5 lug setup for the rear. The front I plan to use EJ stuff. The rear I am looking at either a bearing swap to make it fit or maybe getting the EJ hub machined down or the EA82 hub redrilled. Will probably do a seperate post for what I find. BW Link to comment Share on other sites More sharing options...
baccaruda Posted December 10, 2007 Share Posted December 10, 2007 EJ mounts will fit through the crossmembers' holes BUT they will be deflected at a bit of an angle.. I can't remember the angle but I'd recommend bending the mounting ears on the brackets a little to get the mounts to sit "level" on the crossmember.. they will last a LOT longer that way. I'll look at my wagon which has STI square mounts on an EJ22 and let you know. Might be able to get a picture for you. Link to comment Share on other sites More sharing options...
Subarutex Posted December 12, 2007 Share Posted December 12, 2007 Quote The EJ22T engine mounts were torn so I need to get a new set. Does the WRX ones fit? Spend the money upfront and get the STI Group N Mounts. See Baccaruda's post about different angles... Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 13, 2008 Share Posted May 13, 2008 s'ko, any news on the swap? I'm going the EJ22T route myself but I'm doing the DOHC swap to it as well:headbang: Link to comment Share on other sites More sharing options...
s'ko Posted July 10, 2008 Author Share Posted July 10, 2008 Thought i would resurrect this old thread today b/c I drove the RX to work today. I was conservative with it b/c I am still uncertain about it's reliability. The first thing that happened was I noticed that all of my gauges stopped working. volt, temp, oil pressure and fuel. I think there is a short or a blown fuse somewhere. I checked to see if the car was charging and it was so I decided to continue. About 15 mins into the ride, I get a CEL. Things are not going down to tubes so I continue on. (CEL turned out to be injector number 1) Impressions. Ohh my gosh is this thing fast. Cruising at 70 mph, the tach was set at 3k rpms. slight hiss from the blow off valve doing it's job. The TOD is still there, I will get some murphy and see if it won't go away with a treatment. Car grinds a bit down shifting into 3rd gear. Looks like I need to pour some of uncle scotty's cocktail into it. Last night I had a friend of mine bleed the brakes for me. After it was all done, we went for a spin and I showed him FT4WD low range lsd goodness and did a sweet peel out. He has a 450 HP WRX and he was pretty impressed. Things to take care of now are- 1) gauges. 2) injector error. 3) HVAC system. some reason there is a short there after I removed the dash molding to get to the cluster 4) route the BOV into the intake stream. (original set up is a bypass valve) 5) uncle scotty's cocktail 6) TOD (MMO treatment) 7) install intercooler sprayer 8) fix muffler leak 9) fabricate hood scoop. (see thread in old gen for info.) Then once I am sure that the car is running well go to the SMOG ref and get it smog. BW Link to comment Share on other sites More sharing options...
subyrally Posted July 10, 2008 Share Posted July 10, 2008 sweet man, now you gotta take lots of pics, drive it to maryland, and take me for a ride in it. Link to comment Share on other sites More sharing options...
cyberbackpacker Posted July 10, 2008 Share Posted July 10, 2008 Sounding good bosko... but now where are pics? Link to comment Share on other sites More sharing options...
Numbchux Posted July 11, 2008 Share Posted July 11, 2008 Quote 1) gauges.3) HVAC system. some reason there is a short there after I removed the dash molding to get to the cluster i would bet these 2 are related. IIRC they have the same power source, when I had the dash apart in my '85, I crushed one of the little backlights for the HVAC system, which shorted, blew the fuse, which took out everything. also, I'd highly recommend the Rislone tranny treatment before the cocktail. seems to clean things out really nicely. in fact, I'm thinking about going back to Rislone, I'm just hesitant to drain $40 worth of tranny fluid for an experiment Link to comment Share on other sites More sharing options...
