kinasabi Posted October 20, 2007 Share Posted October 20, 2007 mixed transaxle oil with atf after rebuild and stupidly still used it in the auto transmission on95 gt wagon motors goin but no drive will this cause the problem the power light comes on at start up and shut down theres no drive or reverse what so ever how do i get the mixed oil out of torque converter:lol: Link to comment Share on other sites More sharing options...
Rooster2 Posted October 20, 2007 Share Posted October 20, 2007 kinasabi said: mixed transaxle oil with atf after rebuild and stupidly still used it in the auto transmission on95 gt wagon motors goin but no drive will this cause the problem the power light comes on at start up and shut down theres no drive or reverse what so ever how do i get the mixed oil out of torque converter:lol: There's a drain plug on the bottom of the AT pan. Pull the plug, and drain out the transaxle oil/ ATF mix. This will drain out about 4 quarts, and leave prolly another 4 quarts still in the trany. Refill with ATF, and see if you can get some movement forward or reverse. If not, let car idle for a while. Maybe that will circulate the new ATF throughout the system to free up the torque converter. Regardless, it is prolly best to fill and drain the the AT about 4 times to rid the trany of transaxle oil. Hope this helps. Link to comment Share on other sites More sharing options...
johnceggleston Posted October 20, 2007 Share Posted October 20, 2007 you may drain out a little more by raising the front off the ground, but you will still need to drain and fill 4 times. or drian and fill enought to get to drive and then have a flush done at a shop for 100% drain. Link to comment Share on other sites More sharing options...
nipper Posted October 20, 2007 Share Posted October 20, 2007 If the tranny is full, you wil get circullation inside the tranny. It will take 4 drain and fills to get everything out. Sadly the oil may have damaged the clutches. The clutches are not desighned to hold up to oil in any large amounts. If the linkage moves preoperly, and you get no motion in any gear, the tranny may be dead. nipper Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 20, 2007 Share Posted October 20, 2007 Yeah - if the transfer clutch pack is damaged to any real degree it may never move again. Once those go out the AT's won't move. The clutch plates aren't meant to be coated in anything but ATF. GD Link to comment Share on other sites More sharing options...
john in KY Posted October 20, 2007 Share Posted October 20, 2007 You stated "after a tranny rebuild" which immediately made me think you broke the pump during the installation. Pull one of the lines going to the radiator and start the engine. No flow and you have another major problem. But if you have flow, just let the engine idle until the transmission is pumped dry. Link to comment Share on other sites More sharing options...
porcupine73 Posted October 20, 2007 Share Posted October 20, 2007 Yikes that is not good for the AT, not good at all. Gear oil has a lot of sulfur and other EP additives which will proceed to attack various parts in the AT. It does however seem like the vehicle should at least move, though maybe not for long. Yes do you get fluid flow from the cooler line? Link to comment Share on other sites More sharing options...
kinasabi Posted October 20, 2007 Author Share Posted October 20, 2007 porcupine73 said: Yikes that is not good for the AT, not good at all. Gear oil has a lot of sulfur and other EP additives which will proceed to attack various parts in the AT. It does however seem like the vehicle should at least move, though maybe not for long. Yes do you get fluid flow from the cooler line?havent checked have jus started draining Link to comment Share on other sites More sharing options...
kinasabi Posted October 20, 2007 Author Share Posted October 20, 2007 john in KY said: You stated "after a tranny rebuild" which immediately made me think you broke the pump during the installation. Pull one of the lines going to the radiator and start the engine. No flow and you have another major problem. But if you have flow, just let the engine idle until the transmission is pumped dry.thank s 4 all the advice every 1 wat i did was use donor moter as old 1 was cooked the tras was fine if nothing wrks i have 5 speed out of 96 rs i could use any probs that u know of apart from the obvious Link to comment Share on other sites More sharing options...
kinasabi Posted October 21, 2007 Author Share Posted October 21, 2007 john in KY said: You stated "after a tranny rebuild" which immediately made me think you broke the pump during the installation. Pull one of the lines going to the radiator and start the engine. No flow and you have another major problem. But if you have flow, just let the engine idle until the transmission is pumped dry. na no flow is that the pump is it will i have 2 drop mtr again 2 fix and how:dead: Link to comment Share on other sites More sharing options...
kinasabi Posted October 21, 2007 Author Share Posted October 21, 2007 porcupine73 said: Yikes that is not good for the AT, not good at all. Gear oil has a lot of sulfur and other EP additives which will proceed to attack various parts in the AT. It does however seem like the vehicle should at least move, though maybe not for long. Yes do you get fluid flow from the cooler line? no no flow Link to comment Share on other sites More sharing options...
nipper Posted October 21, 2007 Share Posted October 21, 2007 kinasabi said: no no flow Then the front pump is wiped out. Do not pass go, dont try anything else. Replace tranny. nipper Link to comment Share on other sites More sharing options...
