tidd1340 Posted October 20, 2007 Share Posted October 20, 2007 Can you do the o-rings in an EA82 without having to do the belts? Mine are in great shape,i just have bad leaks..thanks! Link to comment Share on other sites More sharing options...
Reveeen Posted October 20, 2007 Share Posted October 20, 2007 Can you do the o-rings in an EA82 without having to do the belts? Sure, you take the belts off, remove the oil pump, and have at it, rebuilding it, putting a new "mickey mouse gasket", and put back what ever belts you choose. BUT: it's not like those belts cost a whole lot, and say they have 40,000 on them, you might as well? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 20, 2007 Share Posted October 20, 2007 Belts rarely show any wear before failure. They always look "great" till they snap in half. It's not the rubber that fails - it's the internal wire's that hold the rubber together. GD Link to comment Share on other sites More sharing options...
tidd1340 Posted October 20, 2007 Author Share Posted October 20, 2007 Thats what i figured..i will do them if i have to go that far. I didnt know if i could just pull the pump off by itself..thanks. Link to comment Share on other sites More sharing options...
idosubaru Posted October 21, 2007 Share Posted October 21, 2007 oil pump is driven by the timing belt, so the belts have to be removed, no way around it. Link to comment Share on other sites More sharing options...
