TheLoyale Posted October 22, 2007 Share Posted October 22, 2007 So whats the name for the Seaform you can pore into the gas and oil?? Should i do it? What will happen?? Tom Quote Link to comment Share on other sites More sharing options...
Turbone Posted October 22, 2007 Share Posted October 22, 2007 Why do some people have such a problem with the search feature? Its called SEAFOAM.....and you can get it at most auto parts stores. Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted October 22, 2007 Share Posted October 22, 2007 seafoam is a brand name, good detergent additive for cleaning efi systems. i use it for oil additive, its the only thing that quiets my lifters on my 19 loyale 1.8litre Quote Link to comment Share on other sites More sharing options...
Durania Posted October 22, 2007 Share Posted October 22, 2007 Walmart here sells it. Ran it yesterday in my brat just poured some into the carb seemed to help but I have a blown intake manifold gasket and is hard to tell with that thing. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted October 22, 2007 Author Share Posted October 22, 2007 Ok i know what Seafoam is!! Because i have ther deep creep stuff. But i wanted to know what the stuff that you put in your gas/oil was called.. And i know" I never think of the search feature.... I'll look at Wal-mart and see what i find.. Because how many types do they make? Quote Link to comment Share on other sites More sharing options...
baccaruda Posted October 22, 2007 Share Posted October 22, 2007 http://www.google.com/search?hl=en&q=seafoam&btnG=Google+Search Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted October 22, 2007 Author Share Posted October 22, 2007 Hey thanx for the link!! I should have checked out there site first.. Quote Link to comment Share on other sites More sharing options...
BlueTrain Posted October 23, 2007 Share Posted October 23, 2007 you could also try searching this site as well. there might be, oh 1 or 2 posts somewhere on here regarding Seafoam. maybe a couple more. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted October 23, 2007 Author Share Posted October 23, 2007 Oh yeah i'm sure theres a thread out there in USMB cyberspace lol! Quote Link to comment Share on other sites More sharing options...
beataru Posted October 24, 2007 Share Posted October 24, 2007 allright all right ladies, howabout this action! Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted October 24, 2007 Author Share Posted October 24, 2007 Holy crap!! Look at that beauty! Thank's bro..... TL Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted October 24, 2007 Author Share Posted October 24, 2007 PS: It's not like slick 50 is it? I will never use that stuff in my Roo, I was told you have to keep useing it...... But i don't think Seafoam is like that.... Quote Link to comment Share on other sites More sharing options...
casm Posted November 1, 2007 Share Posted November 1, 2007 PS: It's not like slick 50 is it? I will never use that stuff in my Roo, I was told you have to keep useing it...... But i don't think Seafoam is like that.... Seafoam's more of a one-shot deal than something that lives in your crankcase for the rest of your vehicle's life - the way I usually do it is to spray about one-third of the can down the intake while the engine's running, switch off and let it sit for around 15 minutes, then put the rest into the fuel tank with a full tank of gas. Be careful when pouring or spraying into the intake since adding too much at once puts you at risk of hydrolock. I personally prefer the spray because it's harder to accidentally spill in too much at once; it's also easier to get it distributed evenly throughout the intake. At about the point where the engine starts bogging down, back off on adding more Seafoam, let the idle come back up to normal, and add more. After you've added your third of a can and let it sit for 15 minutes or so, start up again (it may be a little reluctant to catch, but this is normal) and set the idle at 2000rpm. Enjoy the smoke show; once the volume of smoke coming out of the tailpipe is around half what it was initially, crank the idle down to around 1500rpm. Once that one's down to half its volume, re-set the idle to normal and let it blow the last of the carbon out. This is how I usually do mine; unless I'm feeling less lazy than normal I don't bother with getting it directly into the intake manifold via the brake booster vacuum line or similar. And I have to say that while I don't believe in miracles-in-a-can, it's worked very well for me over the years on both carburetted and fuel-injected vehicles. With 173,200 miles on the clock, the Brat now has much improved throttle response, smoother idling, and less top-end din (it still needs a carb rebuild, but there's only so much Seafoam can do ). For about six bucks a can twice a year, it's well worth it. One thing I'll add: I've never used it in the crankcase. My preference is to do a diesel flush prior to whichever oil change falls at the six-month mark, so can't really comment on Seafoam's effectiveness there. Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted November 1, 2007 Author Share Posted November 1, 2007 Yeah that's what i was kinda thinking, I think i'll do that with the spray can right into the TB.. Should i pull the air intake off the TB or shoot it into the IAC hose? Because Mike said if i pull the big rubber air intake off the TB it will cause a hugh vaccum leak and will be hard to keep it running which is ture. But don't worry about it i'll figure it out.. later bro.... PS: Happy to hear it helped you Brat alot. Nice brat too!! -Tom Quote Link to comment Share on other sites More sharing options...
casm Posted November 1, 2007 Share Posted November 1, 2007 Yeah that's what i was kinda thinking, I think i'll do that with the spray can right into the TB.. Should i pull the air intake off the TB or shoot it into the IAC hose? Because Mike said if i pull the big rubber air intake off the TB it will cause a hugh vaccum leak and will be hard to keep it running which is ture. But don't worry about it i'll figure it out.. Yep, TB's the easiest. Unless you're planning on cleaning the IAC itself at the same time, the TB's probably your best bet. PS: Happy to hear it helped you Brat alot. Nice brat too!! Thanks! Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted November 2, 2007 Author Share Posted November 2, 2007 Alright i'll give it a try sometime.. Thank's alot! -Tom Quote Link to comment Share on other sites More sharing options...
mudduck Posted November 2, 2007 Share Posted November 2, 2007 I still haven't figured out what seaform yet:confused: Quote Link to comment Share on other sites More sharing options...
TheLoyale Posted November 2, 2007 Author Share Posted November 2, 2007 I still haven't figured out what seaform yet:confused: Ok, OK!! God sorry for the type-o! There i think i changed the title of the thread. Happy? -Tom Just messin' man! Quote Link to comment Share on other sites More sharing options...
