madmat Posted October 23, 2007 Share Posted October 23, 2007 My OBW ej25 auto has started stalling all of a sudden. when you slow down to idle sometimes it will run fine other times it will slow down and then stall. it always starts easy and straight away. it seems to be worse cold but happens when it is hot as well. Could it be the IAC and if so where is this located? I have noticed that the idle has been about 50 rpm low for a while but didn't think much of it until now. Thanks for the help Madmat Link to comment Share on other sites More sharing options...
OB99W Posted October 23, 2007 Share Posted October 23, 2007 Welcome to the forum. There are a few possible causes of what you've described. Can we assume that the CEL isn't lit? What model year is your car? Here are a couple of links to info that may be helpful: http://endwrench.com/images/pdfs/Fuel.pdf http://endwrench.com/images/pdfs/LegacyIdleSum04.pdf By the way, could you actually drive your OB in the "Outback"? (It seems "Madmat" and "Sydney" = Australia ) Link to comment Share on other sites More sharing options...
porcupine73 Posted October 23, 2007 Share Posted October 23, 2007 Hi and and to the board! What year is this soob? Here's a good article about IACV/ISV cleaning for the styles with the IACV on top of the throttle body: http://endwrench.com/images/pdfs/ISCSpring04.pdf Link to comment Share on other sites More sharing options...
madmat Posted October 23, 2007 Author Share Posted October 23, 2007 Thanks guys i will check out the sites and info later. The CEL is not on and it is a 97 i have had the joy of the headgaskets blowing as well. as we would say "Not happy Jan". Yes i can drive the OBW in the real outback but the sad thing is i havn't done it yet. so sad. i have taken it into some serious offroad situations though and am always amased at where the OBW can go. and i used to have a hard core 4wd before the OBW so i know what hard core is. check out this site for a 4wd comp run in the outback. http://www.outback4x4challenge.com/ Madmat Link to comment Share on other sites More sharing options...
