tuner-automotive Posted October 23, 2007 Share Posted October 23, 2007 Im picking up a solid 1 owner 94 Legacy 2.2L 5MT tomorrow. Its just one of my many buy and sell subarus. The tranny has never given the PO any problems and the clutch is 2 years old. It wines in all gears but goes into all gears without any crunches or grinds. It has been whining like this for about a year. Im gonna swap out the fluid when I bring it in for inspection and tuneup before it goes up for sale. Any recomendations as far as gear oils and or additives to use to help quiet that bad boy down. These trannies will go for days with the whine so thats really of no concern to me. Id just like to help queit it down and change the fluids for the next owner. Link to comment Share on other sites More sharing options...
gbhrps Posted October 23, 2007 Share Posted October 23, 2007 RedLine MT90 is what you want. I discovered it 3 years ago on the TwinTurbo.net forum (1990-1996 Nissan 300zx owners). There are 100's of Z owners who had noisy trannies, and those that had gear grinding problems that simply disappeared or were dramatically improved after replacing the gear fluid with the MT 90. When I first got my 1954 MG the tranny was a bear to shift and noisy to the point that I gave thought to rebuilding it. After finding the acclaims on the 300ZX forum about it, I decided to drain the MG tranny and give it a try. The tranny now (it is after all 53 year old technology) makes no noise at all, is much easier to shift, and I seldom grind a gear unless I hurry things. The specs on the bottle also say that it won't corrode bronze synchronizers, important on my old car but maybe not necessary on a more modern unit. No, I don't sell the stuff, but I am very pleased with the results it gave me. Link to comment Share on other sites More sharing options...
dhise Posted October 24, 2007 Share Posted October 24, 2007 I put the redline 75w90NS in my wagon's trans to help with the cold weather shifting (which it did big time) and one of the side benefits is that the tranny gradually made less noise. I also put an ounce or two of autorx in there as well. It is one of the nicest shifting tranny's I've ever owned now. -Doug Link to comment Share on other sites More sharing options...
tuner-automotive Posted October 24, 2007 Author Share Posted October 24, 2007 Did you AutoRx it with the Redline or before it then drain? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 24, 2007 Share Posted October 24, 2007 Scotty's Cocktail. It's AWESOME. My 94 GT shifts like new..... maybe better. 1 Qt Redline Lightweight Shockproof 1 Qt Pennzoil Syncromesh 2 Qt Castrol Hypoy-C 75w90 A ton of folks at legacycentral have used it, and I have to say that I'm a convert. I've tried just the plain Redline synthetics, but there is no comparison between them and the shockproof. Before I changed the fluid I was getting some slight grinding after warm-up, and couldn't go into 1st above 5 or 10 MPH. Now I NEVER get a grind, and can hit 1st at over 25 MPH rolling. There's also concern that using plain MT90 will eventually cause front diff damage to the Subaru transaxles. Unlike other manual transmissions, ours have an integrated hypoid differential. MT90 isn't a differential oil, and doesn't contain the required sulfer. Thus the Hypoy-C in the cocktail.... besides this works better than MT90 hands down. The shockproof is some really crazy stuff - it's bright blue in color too! About $10 a quart same as the MT90, but the other components are cheaper - $4.99 for the Castrol, and $6.99 for the syncromesh here. GD Link to comment Share on other sites More sharing options...
Virrdog Posted October 26, 2007 Share Posted October 26, 2007 I have found in a lot of cases that the transmission mount will contribute to synchro woes... don't ask me how. But keeping everything lined up in the drivetrain is important. Link to comment Share on other sites More sharing options...
dhise Posted October 26, 2007 Share Posted October 26, 2007 tuner-automotive said: Did you AutoRx it with the Redline or before it then drain? I did it before and after the drain, so there's some in there right now. The shifting has gradually improved since I put the new fluid in, we're talking over the course of spring and early summer. So I am assuming the redline helped in the cold weather department and the autorx helped the shifting, because it cleans very slowly. -Doug Link to comment Share on other sites More sharing options...
tuner-automotive Posted October 31, 2007 Author Share Posted October 31, 2007 Im still trying to figure out if my tranny mount is bad? How much play should there be in the mount? Link to comment Share on other sites More sharing options...
eryque Posted October 31, 2007 Share Posted October 31, 2007 GeneralDisorder said: Scotty's Cocktail. It's AWESOME. My 94 GT shifts like new..... maybe better. 1 Qt Redline Lightweight Shockproof 1 Qt Pennzoil Syncromesh 2 Qt Castrol Hypoy-C 75w90 Does anyone know what retailers sell this stuff? I stopped at Advance Auto last night and found that they didn't have any of this stuff. In fact, they didn't have any gear oil that I thought was all that great, so I walked out without anything. Link to comment Share on other sites More sharing options...
Virrdog Posted October 31, 2007 Share Posted October 31, 2007 tuner-automotive said: Im still trying to figure out if my tranny mount is bad?How much play should there be in the mount? Just replace it. It will feel like its made out of Nerf material. Group-N tranny mount you can't even flex from standing on it (at least I couldn't with my massive 150 lbs). Link to comment Share on other sites More sharing options...
tuner-automotive Posted October 31, 2007 Author Share Posted October 31, 2007 "nerf material" thats exactly what my 96 outbacks feels like and it has a deceleration rattle from underneath between the front seats. I already removed all the heat shields trying to fix that noise. Only happens when I down shift and the engine back pressure kicks in. Probably should replace it. Dealer only part? Link to comment Share on other sites More sharing options...
Virrdog Posted November 1, 2007 Share Posted November 1, 2007 https://www.innovativetuning.com/catalog/product_info.php?products_id=1221 Link to comment Share on other sites More sharing options...
hooziewhatsit Posted November 1, 2007 Share Posted November 1, 2007 eryque said: Does anyone know what retailers sell this stuff? I stopped at Advance Auto last night and found that they didn't have any of this stuff. In fact, they didn't have any gear oil that I thought was all that great, so I walked out without anything. www.grimmspeed.com carries all of them. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 1, 2007 Share Posted November 1, 2007 Pep-Boys had the Pennzoil, and the Castrol... Any Redline retailer can order the shockproof. Baxters Auto Parts here carries it, and there's a few other places the carry Redline and could get it if I asked. But yeah - this isn't a one-stop shopping experience trying to find this stuff unless you don't mind paying an assload in shipping It's WORTH IT though. Trust me. You won't beleive it's the same tranny. A guy at Legacy central actually had his father ask him if he swapped the tranny or had it rebuilt.... that's how different it feels. Feels like a new car every time I drive mine GD Link to comment Share on other sites More sharing options...
tuner-automotive Posted November 1, 2007 Author Share Posted November 1, 2007 Ive seen this recipe all over the place and many people have done it but has anybody had any bad experiences with the mix? Oh yeah , no Pep Boys in salem. Link to comment Share on other sites More sharing options...
Turbone Posted November 2, 2007 Share Posted November 2, 2007 If you cant find the stuff locally and want to buy on line, I found it all on Amazon.com. http://www.amazon.com/s/ref=sr_hi/002-5242975-9947269?ie=UTF8&rs=15718791&rh=n%3A15684181%2Cn%3A15718791&page=1 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 2, 2007 Share Posted November 2, 2007 tuner-automotive said: Ive seen this recipe all over the place and many people have done it but has anybody had any bad experiences with the mix?Oh yeah , no Pep Boys in salem. None up here either - bought the stuff in Reno while visiting. But he's in New York so I thought I would mention it.... :-p GD Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 2, 2007 Share Posted November 2, 2007 tuner-automotive said: Ive seen this recipe all over the place and many people have done it but has anybody had any bad experiences with the mix?Oh yeah , no Pep Boys in salem. I read all the threads on Legacycentral I could find, and lots more on Nasioc. Not a single report of any problems. And there's lots of modified turbo guys over there so if anyone was going to find it they would. Even lots of WRX owners are using it as they find that after only 20k or 30k they start to get grinds on fast shifting. 135k, and 14 years on my Legacy's MT - it was grinding when shifting fast from 1 to 2. Not bad, but I could feel it. And I couldn't get into 1st without being very careful while rolling. Maybe in the end it will shave a fews tens of thousands of miles off the life of the front diff, but really what's smooth shifting worth to you? And frankly is grinding the syncros to dust any better of a failure than having the front diff grenade at 300k? I know these things will last for 500k if you baby them but I don't own an AWD 5 speed so I can baby it! Screw that - I want it to shift awesome and feel amazing right up till it blows the ring & pinion right out the side of the case! When I'm done with the car I want it to be "all used up". Used tranny's aren't that expensive anyway. GD Link to comment Share on other sites More sharing options...
tuner-automotive Posted November 2, 2007 Author Share Posted November 2, 2007 well unfortunatly I already bought 6 qts of Redline 75w90ns last week. 3 for the 94 MT and 3 for the 96 outback MT , so looks like Im just gonna try that route and hope it works. They were $10 a qt so Im already into it $60. Link to comment Share on other sites More sharing options...
eryque Posted November 3, 2007 Share Posted November 3, 2007 hooziewhatsit said: www.grimmspeed.com carries all of them. It turns out that Grimmspeed even put together the cocktail mix to save you a couple of bucks. Shipping is $15, though, so I'm not sure the tradeoff is worth it. In the end I was tired of look. Do you guys mix the cocktail before putting it in, or just put it in directly from the bottles and let the tranny mix it up for you? Link to comment Share on other sites More sharing options...
Turbone Posted November 3, 2007 Share Posted November 3, 2007 eryque said: It turns out that Grimmspeed even put together the cocktail mix to save you a couple of bucks. Shipping is $15, though, so I'm not sure the tradeoff is worth it. In the end I was tired of look. Do you guys mix the cocktail before putting it in, or just put it in directly from the bottles and let the tranny mix it up for you? Wish I had known that last week. Oh well, its ready to go in. I mixed it all up in a 1gal container and bought a pump. Results will be posted next week:headbang: Link to comment Share on other sites More sharing options...
tuner-automotive Posted November 6, 2007 Author Share Posted November 6, 2007 So the innovativespeed site shows that rear trans mount for a WRX. I need one for a 96 2.2l 5MT Outback. Is it compatible? Link to comment Share on other sites More sharing options...
subuAL Posted December 7, 2007 Share Posted December 7, 2007 GeneralDisorder said: Scotty's Cocktail. It's AWESOME. My 94 GT shifts like new..... maybe better. 1 Qt Redline Lightweight Shockproof 1 Qt Pennzoil Syncromesh 2 Qt Castrol Hypoy-C 75w90 A ton of folks at legacycentral have used it, and I have to say that I'm a convert. I've tried just the plain Redline synthetics, but there is no comparison between them and the shockproof. Before I changed the fluid I was getting some slight grinding after warm-up, and couldn't go into 1st above 5 or 10 MPH. Now I NEVER get a grind, and can hit 1st at over 25 MPH rolling. There's also concern that using plain MT90 will eventually cause front diff damage to the Subaru transaxles. Unlike other manual transmissions, ours have an integrated hypoid differential. MT90 isn't a differential oil, and doesn't contain the required sulfer. Thus the Hypoy-C in the cocktail.... besides this works better than MT90 hands down. The shockproof is some really crazy stuff - it's bright blue in color too! About $10 a quart same as the MT90, but the other components are cheaper - $4.99 for the Castrol, and $6.99 for the syncromesh here. GD Hey GD, My 94 Legacy MT is noisy, very noisy. I'm going to try Scotty's Cocktail. Unless something even better has come about since oct? Please give me a heads up if there's something else I should consider. Thanks, Al:headbang: Link to comment Share on other sites More sharing options...
eryque Posted December 7, 2007 Share Posted December 7, 2007 Al, there's another thread (started by me) in which a lot of people say this cocktail is crap. I used it in my car and shifting is actually a little worse than it was before, and there's some info about the Redline Shockproof being bad news. Link to comment Share on other sites More sharing options...
