TheBush Posted October 23, 2007 Share Posted October 23, 2007 So here's the deal. 1986 GL10....it starts and all that fun stuff, but the engine won't run unless we are spraying starter fluid down the intake....we've checked the fuel pump, all is good. It is getting fuel, no problem. Could it be the fuel pressure sender or whatever? Any other suggestions.... Desperately need help! Link to comment Share on other sites More sharing options...
idosubaru Posted October 23, 2007 Share Posted October 23, 2007 is this SPFI? check the injector itself, is it clicking at all? can probably check resistance too. where did you check for fuel? is fuel getting past the fuel filter? i've heard of those little fuel pressure diaphragms failing, but never had it happen so i don't know what happens when they fail. but yes, i do know they can cause problems of some sort. i believe they have a vaccuum hose as well, make sure that's connected and not clogged. Link to comment Share on other sites More sharing options...
TheBush Posted October 23, 2007 Author Share Posted October 23, 2007 Its a turbo, EA82T so it'd be MPFI. We checked from the fuel filter, both sides of it and its getting fuel just fine... Link to comment Share on other sites More sharing options...
idosubaru Posted October 23, 2007 Share Posted October 23, 2007 i'd replace that fuel pressure diaphragm. never had to deal with them, so i'm not sure but there may be an easy way to test yours as well. i'd imagine there is. what's the history? has it sat for awhile? did it gradually crap out or quit one time? it's not bad/old gas? Link to comment Share on other sites More sharing options...
TheBush Posted October 23, 2007 Author Share Posted October 23, 2007 Ran Fine. Yesterday I went into a mud puddle...about 5 minutes afterwards i started to notice this....i bearly made it home, it died as i turned into my driveway. Now it won't run at all... Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 23, 2007 Share Posted October 23, 2007 Could be electrical - use a noid light to make sure the injector is even fireing. GD Link to comment Share on other sites More sharing options...
idosubaru Posted October 23, 2007 Share Posted October 23, 2007 i mean to ask - any check engine lights now or recently? how big was this mud puddle? i'd remove your distributor cap, get everything dry as a bone in there. i think you'll find your injectors aren't firing like GD said...and it may be due to the distributor getting wet - crank sensor being miffed. Link to comment Share on other sites More sharing options...
TheBush Posted October 23, 2007 Author Share Posted October 23, 2007 Mud puddle wasnt even that big....took off disty cap, its dry in there.... Link to comment Share on other sites More sharing options...
idosubaru Posted October 23, 2007 Share Posted October 23, 2007 any answer on the check engine light? i think i'd still want the plugs, wires, cap, disty, rotor to all be aired out. Link to comment Share on other sites More sharing options...
Cougar Posted October 24, 2007 Share Posted October 24, 2007 I thought that MPFI didn't come out until '88 but I could be mistaken. The problem does seem to be with the injector(s) and need to be checked, as was mentioned. Link to comment Share on other sites More sharing options...
TheBush Posted October 24, 2007 Author Share Posted October 24, 2007 Ehh...maybe it is SPFI. I really didn't know, I just thought that turbo cars always had multi port... Link to comment Share on other sites More sharing options...
joostvdw Posted October 24, 2007 Share Posted October 24, 2007 I know that the 87+ dizzy has a sensor wheel with small slots (cam/crank position sensor) under a metal plate under the rotor, so you can't see it, but it may still be dirty or wet. have you checked simple things? like connectors corroded/wet? no vacuum hoses came off? Link to comment Share on other sites More sharing options...
subaruguru Posted October 26, 2007 Share Posted October 26, 2007 HEY lol thats what the car did after i went through a puddle. but i doubt you put a hole in the block. check the maf sensor if it has water in it then thats your problem. other than that idk. yes it is mpfi all turbos are and an easy way to check that is there will be an injector over each spark plug. Link to comment Share on other sites More sharing options...
