WoodsWagon Posted October 24, 2007 Share Posted October 24, 2007 I'm used to having a pile of shims on each side of the case where the bearing cap goes in on the R160 diffs. The one I pulled apart today had NO SHIMS. Does this mean someone took it apart in the past and didn't put them in, or should I put it back together with no shims? I don't really want to do the whole backlash/contact pattern adjustments but not having any shims worries me. It looked like an origional gasket on the rear cover, and the level of corrosion was in line with it never having been taken apart before.. Link to comment Share on other sites More sharing options...
Phizinza Posted October 24, 2007 Share Posted October 24, 2007 I say if it doesn't make any unwanted noise while driving, just don't worry. I do doubt that it came from the factory "perfect." Sounds like something pulled it apart and didn't know/care what the shims are. Link to comment Share on other sites More sharing options...
Ross Posted October 24, 2007 Share Posted October 24, 2007 91Loyale said: I'm used to having a pile of shims on each side of the case where the bearing cap goes in on the R160 diffs. The one I pulled apart today had NO SHIMS. Does this mean someone took it apart in the past and didn't put them in, or should I put it back together with no shims? I don't really want to do the whole backlash/contact pattern adjustments but not having any shims worries me. It looked like an origional gasket on the rear cover, and the level of corrosion was in line with it never having been taken apart before.. Best to check it.... I have found rtv to be a good easy substitute for 'blue' - easier to see in low light etc... Link to comment Share on other sites More sharing options...
