Bluestone Posted October 24, 2007 Share Posted October 24, 2007 What size socket do I need for the (manual)gearbox drainplug on my 2000 Legacy. Also, the differential filler and drain plugs take a 1/2 inch square "male", right? Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted October 24, 2007 Share Posted October 24, 2007 For the rear diffs, a 1/2" drive breaker bar or such will work. I use a 1/2" pipe plug socket. It's probably actually metric like 13mm or something but 1/2" seems to work. Transmission drain plug might be 17mm; I have all autos. Common soob fasteners are headed 8mm, 10mm, 12mm, 14mm, 17mm, 19mm, 22mm Newer soobs use a T70 torx for the transmission items to hopefully keep the iffy lube type places from draining it when intending to drain the engine oil. Quote Link to comment Share on other sites More sharing options...
Hondasucks Posted October 27, 2007 Share Posted October 27, 2007 Engine and Trans drains are 17mm, manual tranns drain is 22mm. Engine and automatic trans drain plugs take the same gasket, and the auto trans diff plug takes the same gasket as the manual trans drain plug, but I don't know the part # off the top of my head (Any repuatble dealer parts dept should have it in stock, it's used on all the new scoobs) Quote Link to comment Share on other sites More sharing options...
