TheLoyale Posted October 26, 2007 Share Posted October 26, 2007 Alright i finaly bought some Seafoam and i wanted to know if it will thin out the oil and couse less protection.. I'm only putting in a little bit.. And is it really a good idea to pull the air intake off the TB and pore some in like it says? And should i really put some in the gas? Just a few questions before i do it. Thank's for any advice, Tom Link to comment Share on other sites More sharing options...
subaruguru Posted October 26, 2007 Share Posted October 26, 2007 first off what are you trying to accomplish?? Rob. Link to comment Share on other sites More sharing options...
TheLoyale Posted October 26, 2007 Author Share Posted October 26, 2007 Well i have rough idel and some light ticking with the lifters. So i wanted to see what would hapen with this stuff. Connie says it does wonders.... Link to comment Share on other sites More sharing options...
BlueTrain Posted October 26, 2007 Share Posted October 26, 2007 your oil pump is probably sucking air. again, the search function here will give you many posts detailing how others have used Seafoam. personally, i don't like to add anything to my oil. Link to comment Share on other sites More sharing options...
TheLoyale Posted October 26, 2007 Author Share Posted October 26, 2007 Yeah i got to get that oil pump stuff done... I have eveything but dad never wants to do it.. So that is the main couse of it.. Now the lifters always have a little noise right? Even when the car was new? Link to comment Share on other sites More sharing options...
subaruguru Posted October 26, 2007 Share Posted October 26, 2007 nope they arnt sposed to make noise. Link to comment Share on other sites More sharing options...
TheLoyale Posted October 26, 2007 Author Share Posted October 26, 2007 Is that bad? Will they wear out? It's just a little very light tick.. I'll have to get that done really soon!!!!! Link to comment Share on other sites More sharing options...
BlueTrain Posted October 26, 2007 Share Posted October 26, 2007 a ticking soob is definitely not a rarity Link to comment Share on other sites More sharing options...
TheLoyale Posted October 26, 2007 Author Share Posted October 26, 2007 It's good i' not alone, I know Bucky used to tick from what Connie say's.. Link to comment Share on other sites More sharing options...
82glsw Posted October 26, 2007 Share Posted October 26, 2007 It's good i' not alone, I know Bucky used to tick from what Connie Say's.. If the tick is not to bad u can add a little marvel mystery oil to your oil and it should quiet things up Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 26, 2007 Share Posted October 26, 2007 Ok here is the deal... it will thin out your oil. It is not bad, but for a prolonged amount of time it isnt good. Run it for a day or a week, then do an oil change. Thats what I use it for. Seafoam is a detergent. It cleans... so its good for cleaning carbon diposits from within your engine. It will also thin the oil and may help with hydraulic lifters. Yes Pour it right into the throttlebody. You car wont like running on it, but it will clean the crap out of your carburator (if you have one) and your valves, piston, etc... And its never a bad idea in the gas. Wont harm anything. I preffer Marvels Mystery Oil over Seafoam. They are pretty much the same thing, however MMO is more of an oil. -Brian Link to comment Share on other sites More sharing options...
TheLoyale Posted October 26, 2007 Author Share Posted October 26, 2007 Yeah it does. But i put that in my Lown mower and it made it blow oil as long as that stuff was in there. So no more of that... Link to comment Share on other sites More sharing options...
TheLoyale Posted October 26, 2007 Author Share Posted October 26, 2007 Yeah MMO is more oily then Seafoam. I will add it to the gas then. It's SPFI by the way.. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted October 26, 2007 Share Posted October 26, 2007 In the gas will help it clean your injector. Link to comment Share on other sites More sharing options...
TheLoyale Posted October 26, 2007 Author Share Posted October 26, 2007 Yeah there might be some dirt in there.. Link to comment Share on other sites More sharing options...
daeron Posted October 26, 2007 Share Posted October 26, 2007 the single best application of sea foam is to detach the vacuum line that feeds the brake booster, on the booster end. Pour 6 ounces of sea foam into a jar or something that you can put the vacuum line down into. Put your thumb over the end of the tube. Have a friend start the engine, remove your finger from the tube, (warn your friend to be ready to give it a little gas so it doesnt stall.) Use the vacuum line to suck up the sea foam; it won't take long. Immediately shut the engine off. (no harm done if you burn some, it just works through soaking.) Let the engine sit for five or ten minutes, and then go for a VERY spirited drive, and watch all the carbon and soot and other combustion byproducts and contaminants that had infiltrated your combustion chambers, and pretty well anywhere the sees manifold vacuum, BURN AWAY in a foul cloud of smoke. I do this once every six months or so, if possible. The in fuel, and oil treatments are less frequent in my book. Link to comment Share on other sites More sharing options...
Davalos Posted October 26, 2007 Share Posted October 26, 2007 ... then go for a VERY spirited drive, and watch all the carbon and soot and other combustion byproducts and contaminants that had infiltrated your combustion chambers, and pretty well anywhere the sees manifold vacuum, BURN AWAY in a foul cloud of smoke. I do this once every six months or so, if possible. The in fuel, and oil treatments are less frequent in my book. Do you do it in a different neighborhood everytime? I would feel guilty doing it every 6 months ... when I did it, I had 2 neighbors come outside and look at me, shaking their heads, then going back in & slamming their windows shut, hehe. Link to comment Share on other sites More sharing options...
TomRhere Posted October 26, 2007 Share Posted October 26, 2007 Do you do it in a different neighborhood everytime? I would feel guilty doing it every 6 months ... when I did it, I had 2 neighbors come outside and look at me, shaking their heads, then going back in & slamming their windows shut, hehe. Does tend to keep the skeeters away for a bit, don't it? Link to comment Share on other sites More sharing options...
mikeshoup Posted October 26, 2007 Share Posted October 26, 2007 the single best application of sea foam is to detach the vacuum line that feeds the brake booster, on the booster end. I don't use the brake booster hose. It will only feed seafoam to the left cylinder bank. You need to use a more central vacuum line in the intake manifold. Link to comment Share on other sites More sharing options...
Virrdog Posted October 26, 2007 Share Posted October 26, 2007 Alright i finaly bought some Seafoam and i wanted to know Dude, I know you're young. But you have waaay too many posts to do stuff like this. Look up Sea Foam in just Old Generation and you should find enough posts to be reading for a week. Then you can come back with new original questions... if there are any left. Link to comment Share on other sites More sharing options...
backwoodsboy Posted October 26, 2007 Share Posted October 26, 2007 I know Bucky used to tick from what Connie say's.. They say a "ticking" sound coming from a subaru engine indicates that it is RUNNING Bucky ticks SOMETIMES. From my experience, at idle (even INCREASED idle at startup) the oil pump doesnt produce quite enough pressure to pump up the lifters.... hence the ticking. I had run Bucky for about 10 minutes last night....... tick tick tick. Then I hit the gas and sent the tach to about 2 1/2 grand (and the ticking stops) Marvel Mystery that bad boy! Link to comment Share on other sites More sharing options...
TheLoyale Posted October 26, 2007 Author Share Posted October 26, 2007 I don't use the brake booster hose. It will only feed seafoam to the left cylinder bank. You need to use a more central vacuum line in the intake manifold. So what? Str8t down the TB opening? Alright i'll give that a try.. Thank's everyone PS: I know i should try the search sometime.. Sorry i'm just a bad boy. Link to comment Share on other sites More sharing options...
mikeshoup Posted October 26, 2007 Share Posted October 26, 2007 So what? Str8t down the TB opening? That works, though sometimes it can be hard to keep the vehicle running since pulling that off creates a large vacuum leak. What I did on my SPFI is unhook the hose that goes into the IAC solenoid from the intake tube. Plugged the hole in the tube with my thumb, and then dumped the seafoam down the hose that runs into the IAC. That will distribute the seafoam fairly evenly. It might not work at hot idle since the IAC would close up, but it did work very well at a cold idle. Link to comment Share on other sites More sharing options...
TheLoyale Posted October 26, 2007 Author Share Posted October 26, 2007 Yeah ok! Hey BTW which hose is for the IAC?? The one in front of the air intake to the TB? I don't think i'm going to add it to the oil. Because i put some in my Lown mower and it blows some blue smoke/oil now?? Is that normal? Link to comment Share on other sites More sharing options...
joostvdw Posted October 26, 2007 Share Posted October 26, 2007 I don't know how "watery" seafoam is, or how fast it evaporates, but if it's anything like water, don't dump it all too quickly into the TB as you may risk hydrolock, use a vacuum hose instead. Link to comment Share on other sites More sharing options...
