sweet obd I scanner tool
Numbchux
well i made one and tryed to use it on my EJ20G, no luck. it gives me an error and says the ROM is unrecognized... but i will see what i can do about that. i would love this thing to work on my car...
as i see it. if it works on the EJ22t it should work on the EJ20G. the ecu pinouts are 90% the same and so is most of the wiring.
well the code is opensorce so i will see if i can get it to work...
-=Suberdave=-
www.suberdave.com
  pisces_0 said:
Care to give me a rundown on that? I burned b10scan.iso to a CD, and told Windows to boot from that drive first but still nothing pops up.
Basically, explain it to me like I'm a five year-old.:confused:
you have to burn it as a backup not just an ISO as a data file on a CD.
i used NERO 7.* and just burned as a backup and it put two files on the CD. then i put it in the rom drive and start up the comp, and it boots from it...
-=Suberdave=-
http://www.suberdave.com
  Numbchux said:
I haven't made the cable yet, so I haven't actually plugged it into the car. but if you just double click on the b10scan.com file in windows XP, and it loaded in a window.....
that works too. but on the webpage it recomends running it from a boot disk, this way the program has 100% of the CPU and memory, and the program can update faster...
-=Suberdave=-
