rweddy Posted October 30, 2007 Share Posted October 30, 2007 So I wanted to get BFT AT's but they don't make them small enough to fit on my soon to be lifted 91 wagon. Anyone have anything good or bad to say about these Yokos? I am putting on 98 outback struts & springs on my 91 wagon. I know I can go 205/70 15 how much bigger can I go? Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted November 1, 2007 Share Posted November 1, 2007 I'm not sure you can go much bigger without rubbing Quote Link to comment Share on other sites More sharing options...
xrturbo Posted November 1, 2007 Share Posted November 1, 2007 I did 205/75/15 on the same setup you are doing. That is about the tallest you will want to run. I ran a General Grabber AT2 which work nice and can be had for a little over $60 ea. And also a couple tips in case you didn't know: you will need to use the 91 strut mounts and also it would be adviseable to smack in the wheel well behind where the lower spring seat would sit, I had problems with a banging noise from rubbage. You can get away without them but I would also strongly suggest the outback lateral control arms with brackets, otherwise it will pull the wheel forward and rub the lip on the lower rocker panel. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted November 1, 2007 Share Posted November 1, 2007 Suggest looking at Kumho tire line, their Solus model is good. I like Kumho tires, good price, great performance. Quote Link to comment Share on other sites More sharing options...
rweddy Posted November 1, 2007 Author Share Posted November 1, 2007 I did 205/75/15 on the same setup you are doing. That is about the tallest you will want to run. I ran a General Grabber AT2 which work nice and can be had for a little over $60 ea. And also a couple tips in case you didn't know: you will need to use the 91 strut mounts and also it would be adviseable to smack in the wheel well behind where the lower spring seat would sit, I had problems with a banging noise from rubbage. You can get away without them but I would also strongly suggest the outback lateral control arms with brackets, otherwise it will pull the wheel forward and rub the lip on the lower rocker panel. Thanks for the info. Can I avoid the rubbing issues & control arms if I just used the outback struts and reuse my 91 springs? Quote Link to comment Share on other sites More sharing options...
