djbroadus Posted October 31, 2007 Share Posted October 31, 2007 2 weeks ago my clutch cable snapped on bainbridge island. Then the other evening leaving the watering hole my lights would not work yet my brights would, drove home with the brights an got home an the normal lights started working..... Now my lights work but when turning on the brights my hatch light comes on...... This morning EGR light is on, mine is bypassed...... Subarus Link to comment Share on other sites More sharing options...
Durania Posted October 31, 2007 Share Posted October 31, 2007 Sounds like you have an alternator on the way out. My hatchback did some goofy things when it started to go on it. I.E.: wipers coming on and blowing every light in the climate control and half in the cluster and my normal running headlights. I too had to drive home with the brights, alot of other pissed off drivers blinded. Link to comment Share on other sites More sharing options...
ivantruckman Posted October 31, 2007 Share Posted October 31, 2007 hahaha my car did the same thing, 85 wagon. i put some mud over the headlight lense to dimm it a bit, drove it for a month like that, what a fun way to drive, improvise on the fly, also had a throttle cable brake, used a tent cord and pulled it thru the firewall. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 31, 2007 Share Posted October 31, 2007 EGR light is timer operated to go on every 60k. There's a couple blue and green connectors you swap under the dash to extinguish it. GD Link to comment Share on other sites More sharing options...
djbroadus Posted October 31, 2007 Author Share Posted October 31, 2007 well i did just click over 180k, that makes sense. alternator is always interesting as well. Link to comment Share on other sites More sharing options...
mudduck Posted November 1, 2007 Share Posted November 1, 2007 You should pull the alt and have it tested. It sounds like its about toast. Link to comment Share on other sites More sharing options...
samneric Posted November 2, 2007 Share Posted November 2, 2007 EGR light is timer operated to go on every 60k. There's a couple blue and green connectors you swap under the dash to extinguish it. GD AaaHAA! That just saved me my next job of investigating the EGR system I should imagine mine has been on since the first 60K so I'm gonna havta switch the connectors a few times to make it go out Steve Link to comment Share on other sites More sharing options...
