tuner-automotive Posted October 31, 2007 Share Posted October 31, 2007 Ive cleaned many a engines before but this time the car wouldnt start after a degrease and then wash of the engine bay. Usually I would suspect a wet distributor but we dont have these on our Subies. Car turns over just fine , just wont catch. Any suggestions? Link to comment Share on other sites More sharing options...
tcspeer Posted October 31, 2007 Share Posted October 31, 2007 Make sure your big vacum line that is in the middle of the air tubing is still connected, it is the one that is around 3/4 in. dia. Other then that leave hood open and let dry. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 31, 2007 Share Posted October 31, 2007 Make sure the coil pack isn't wet, and the leads are secure. GD Link to comment Share on other sites More sharing options...
porcupine73 Posted October 31, 2007 Share Posted October 31, 2007 Maybe also see if there is any arcing off the spark plug wires; if so replace wires. Link to comment Share on other sites More sharing options...
Rooster2 Posted October 31, 2007 Share Posted October 31, 2007 If 110v outlet is near by, suggest using a couple of portable hair dryers on the motor to dry up any moisture. I have done that before, and it helps. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 1, 2007 Share Posted November 1, 2007 WD40 will dry it quicker than a hair dryer. GD Link to comment Share on other sites More sharing options...
tuner-automotive Posted November 1, 2007 Author Share Posted November 1, 2007 2 days of sitting and still no catch of the motor. Just starter turning over. Engine is dry. Link to comment Share on other sites More sharing options...
tuner-automotive Posted November 1, 2007 Author Share Posted November 1, 2007 Im now leaning towards a wet ICM as my culprit as its the ONLY thing that would really prevent the start of the engine. Link to comment Share on other sites More sharing options...
tcspeer Posted November 1, 2007 Share Posted November 1, 2007 You are probably not getting fire, but I would check and see if fuel is getting to the engine also. You may have water down in the spark plug holes, I would check. Did you check that big vacum hose? It has gotten more then one of us. Im now leaning towards a wet ICM as my culprit as its the ONLY thing that would really prevent the start of the engine. Link to comment Share on other sites More sharing options...
tuner-automotive Posted November 1, 2007 Author Share Posted November 1, 2007 Yes that hose is intact, thanx. Feels like its getting fuel , just no spark. Link to comment Share on other sites More sharing options...
porcupine73 Posted November 1, 2007 Share Posted November 1, 2007 Are you seeing any arcing in there if it's dark out whilst cranking? Link to comment Share on other sites More sharing options...
